scott_mcleod
My D700 has a strange "blurry band" that runs vertically almost smack through the middle of the frame (very slightly to the left of the center focus indicator). It's pretty subtle but does get in the way when trying to use manual focus. My D300 screen is completely uniform with no irregularities whatsoever.
Has anyone else noticed this? You have to look very closely to see it, and the subject has to be textured and fairly contrasty, but when moving the camera slowly over something that has a lot of detail, like a tree with foliage, it becomes pretty obvious. I am considering buying a stock replacement screen (as a spare part) and swapping it to see if it has the same problem. I tried an aftermarket screen but it had an entirely different (design) "issue" that made it unusable.
This camera has already been back to Nikon to try and sort out a related issue - the image in the VF is slightly OOF when the AF has locked (correctly), and when focusing manually, when the VF is sharp, the captured image is slightly OOF. This is a problem that seems to affect lenses over 50mm much more than shorter ones.
Any advice on this topic would be greatly appreciated! I ADORE the file quality from the D700 (my D300 is very noisy, and the way it shoots in 14-bit mode is rather underwhelming) but this VF/focus issue is driving me nuts to the point I am thinking of selling it.
Scott
Scott
