Hello,
This is my first post in your forum.... and English is not my mother language ....
I will share this stroboscope mode of a flash for stills.
I am a hobby photographer, and maybe this technique is nothing new, well known and you talk every week about it. If so, please say so, because I would like to see their pictures and how they use it and so on.
I have a Metz 58 AF-1 digital and this flash has such a stroboscope mode (beside manual, A-mode, P-TTL (yes, I am a Pentax user) and P-TTL HSS.
I didn't know what I personally can do with this stroboscope mode, ok, I know how you use it normally, but I do not such pictures.
The idea came when I made my flower pictures and some I posted in our (Pentax-forum) monthly flower thread.
So, I hold the flash in my hand (the flash is not connected to the camera) and during the 8.sec shutter speed time, I move the flash around. For to start the flash*s stroboscope run, I must only press the test button on the flash, and it starts. During this 8 sec. (I like to use such 8 sec., but it is not a must) I can start the flash 2-3x , so every single run has 16 single flashes -> I use between 32...48 single flash lights and all from different directions. The exposure is pur "handmade", because I regulate the exposure:
- how long I stay at one direction and do not move
- how big is the distance to my subject ( for the pictures I post here -> ca. 1....0.5 meter)
- you must not use ever single flash during a run, just hold the flash during a run not pointed all the time to your subject .... I let it illuminate the room than.
My flash and the grid tool (the CTO I use only when I need to match the WB to an extern tungsten light source in the scene .... but not for this pictures)
my setting for the flash is (mostly):
examples:
Orchids are wonderful for to let the light shine through the leaves
the next picture : the light from all the different directions (all single flash has only a min. power of 1 /225) let the inner structure of the flower get visible
next picture: light from the side and nearly on light from the top
you must of cause not only take pictures of flowers ;-)
next picture: light was coming from a lot different directions
this technique do such a lot fun !
EDIT: .... and now the big "but": when you make 5 pictures, every picture will be different ! you are nearly not able to redo your movements, when you will change for example only a minor point in one illuminated area. Every single picture is quasi a uniat. That I like a lot, but maybe not everybody. Therefore, you can add workflows like:
the camera is anyway on a tripod, so take some pictures where you let the flash only 1x run and therefore your subject is only in a part well illuminated. Than the next pictures also only one run, but with an other direction and so on. In PS you use than the pictures with good illuminations (or erase the bad areas) as additional layer and on that way you built up what I do via one picture during the 8 sec. And of cause you can burn the too dark areas in PP up to your taste.
I don't know your cameras, but this PS layer workflow I can simulate with for example my K1, when I use multiexposure. My K1 show me after the first picture the result on my display, and with this, I can decide if I need at this or that area more light on my subject and do this in the next picture-run. Now my room is dark, and than I can see this pictures on my K1's LCD relative well.
BTW: how dark must the room be for my 8 sec. ?..... just do a picture and look, how your subject looks like via only using the "ambience" light. Via this test, you can also use a ratio with ambience light/ stroboscope flash light ... but than, use a CTO for the flash, else you get two different WB into your picture and this you can not match in PP.
best regards KPM2
examples:
best regards KPM2
