Use a Flashpoint R2 Single Pin Transceiver to trigger a Flashpoint R2 Pro MarkII Transmitter?
Ken Minolta
Well-known member
I am watching a Mike Burke YT video - and he's using a Flashpoint R2 Single Pin Transceiver to trigger a camera that has a Flashpoint R2 Pro MarkII Transmitter on it's hot shoe. How is this possible?
Can a Transceiver Trigger a Transmitter?
I can understand how a Transmitter can trigger a Transceiver, but the other way around? That doesn't make sense.
I'd like to use the inexpensive Transceiver as a remote shutter release - with the Transmitter firing the flash (communicating with the AD200 flash)
I already own the Pro MarkII Transmitter - buy have been using the shutter release button on the camera. I'd really like to be able to be away from the camera when triggering the shutter/flash.
Thoughts?
thanks.
Without seeing the YT video (posting a link would have been helpful) I suspect there should be a SPT at the camera connected to the camera's remote shutter port.
Godox XT1, XT2, XPro, and XPro II have no receiver capability built in.
Well yes and no. You could put the transmitter in the top hot-shoe on the SPT or wiring them together via PC ports may be possible. Now the transceiver is triggering the transmitter.
Using a pair of SPTs for the remote shutter function with your XPro II in the hot-shoe will require the SPTs to be on a different channel than your transmitter/lights. If on the same RF channel the lights will fire early.
You could put an SPT in the hot-shoe and wire it to the remote shutter port. Your hand-held SPT when set to one channel number higher than what the lights/camera SPT use will trip the shutter only. The lights will fire in correct sync with the shutter. Unfortunately the SPTs don't support TTL or HSS flash, only manual.
Thoughts?
thanks.
You are welcome.
  • John
  • Like
Reactions: kli
The R2 Single Pin Transceiver has a shutter release mode. The shutter isn't triggered via the flash shoe -- it's done by connecting a shutter release cord between the R2 and the camera.
That's the way I do it with PocketWizards: one set of radios - one in my hand and the other connected to the camera's remote input and another Pocketwizard or Raven in the camera's hotshoe to communicate with the flashes.
