fairfaxian
Leading Member
I have a fairly short time lapse sequence. Shot fully manual -Exposure, focus, color temp etc. Camera Raw format. 1 frame per second. (only 715 frames)
It's a mountain summit in rolling fog at dusk, (setting sun - tail end of golden hour into to blue hour). I made my best guess for exposure for the first exposure. The sequence will get slowly more under-x.
I believe there is software that can vary the exposure gradually over time. Is there a way to go this in Camera RAW, PShop, or perhaps Adobe Premiere? It's easy to process frame #1, then apply those settings to all the frames using Adobe Bridge. I typically process raw files in Camera RAW, applying any further adjustments in PShop. Primarily a stills shooter, I have only made a few time-lapse sequences.
I just previewed in Adobe Bridge, holding the right arrow key for a quick animated simulation. Looks good, nice fog movement, etc. Might want to adjust exposure gradually over time towards end of sequence.
I'm pretty bad at math (tired now too) but I believe this should yield about 29sec sequence at 24fps? 29 secs is probably a tad long to hold interest on this, but as each frame is 8192x5464, I can zoom slowly (dolly in) gradually so it's not too static. Also adjust the timing to shorten if necessary.
Suggestions on gradually exposure compensation?
Thanks!
Thanks!
