Hugh Barstead
Forum Enthusiast
Using a Mac Studio M3 Ultra (standard config with 28 core CPU, 96 GB RAM and 1 TB HD), additional storage was required. The solution was to employ an external M.2 drive in a Thunderbolt 5 enclosure for maximum speed.
There are few choices in external drives with TB5 connectivity. A couple of complete drives and a couple of enclosures were all that were available for immediate order.
Of those, an enclosure from Acasis was the only one incorporating a cooling fan so it was procured, model number TB501Pro, advertising 80 Gb/s speed.
The requirements for the M.2 NVME drive are specific. It must be a 4 lane stick employing PCIe Gen 4. The enclosure does not support Gen 5.
On hand was a WD_Black SN850X NVMe™ SSD, 2TB. It fit all the requirements and seemed fast enough so it was installed in the Acasis.
The drive was plugged into the Mac using the Acasis supplied cable and formatted with the Apple disk utility in APFS to match the internal drive. Approximately a half TB of miscellaneous data files were then transferred to the drive prior to testing to better simulate real world conditions.
Blackmagic’s Disk Speed Test was used to check the throughput. This software was selected due to familiarity.
The results are noteworthy. To begin with, both the internal and external drives wrote faster than they read. No fluke, repeated testing and reinstalling the testing software yielded exactly the same results.
Those results were fast. First, the internal 1 TB drive:
Internal Drive
Then the external 2 TB Thunderbolt 5 drive:
External Drive
Note: When testing, no two results were identical. The widest variation was on the order of 8%. The results shown are “typical” in that they are close to the mean.
To complete the testing a 138.1 GB .NEV file was transferred from the external to the internal drive using a Finder copy. Timing the transfer was considered accurate to within 0.1 second.
The transfer took 22.93 seconds which results in a 6.023 GB/S transfer speed. This is actually slightly faster than the results from the Blackmagic testing (taking the lower read speed into account), likely due to the single monolithic file transfer.
Transferring the same file from the internal to the external drive took slightly longer, resulting in a transfer speed of 5.4 GB/S. Speculation was that this was due to the slower read speed of the internal drive, however this is just an uninformed guess.
While the TB5 enclosures are still quite expensive (the Acasis cost ~ $225 U.S., plus the cost of the drive) it is still far less costly than Apple’s drive pricing.
With the TB5 drive closely matching the speed of the internal drive it makes sense to go this route rather than paying Apple. NB: The larger drives provided by Apple may or may not be significantly faster than the 1 TB drive contained in the test Mac Studio. Any info on this would be appreciated.
In comparison a PC equipped with a USB-C 3.2 Gen 2x2 card and an appropriate drive and cable attached delivered 1.8 GB/S under similar test conditions. This amounts to 72% of the theoretical 20 Gb/S speed available.
TB5 appears to be three times faster while using only 60% of the theoretical throughput. Perhaps efficiency gains in the future will provide even more speed.
Certainly there is much to criticize in the testing methods employed. The write speeds that are faster than the read speeds is unusual. However experience in real world usage shows that the tested speeds are realized in practice. Perceived speeds of the internal and external drives are essentially identical.
Input from anyone with TB5 drive experience is welcome.
Internal Drive
External Drive
