If you have the E10 or E20 I would appreciate if you could do the following test and email me the results at .
Reason for the test - ongoing discussion with Olympus about manual focus.
Test:
1. Set up test chart (piece of 8.5x11 paper with one horizontal black line and three vertical black lines which can be marker pen) about 24" from camera that is mounted on tripod and illuminated with any light that is bright enough to focus the chart. You do not need to take any pictures.
2. Make sure your eye piece is set for the sharpest image with your eyes. This is done by pointing the camera at a white piece of paper and turning the diopter adjustment until the black rectangle and circle are as sharp as possible.
3. Set focal length to 36mm and lens opening to f2.4 (shutter speed not material) and no filters.
4. Turn on camera and LCD and get distance scale.
5. Set focus to manual and adjust focus until you have the best possible image in the viewfinder. Note distance on LCD scale.
6. Close the viewfinder blind, switch to auto focus, 1/2 press shutter while watching the LCD distance scale.
Please report if ANY (little or lot) or NO movement of this scale. Repeat several times and see if same thing happens and is consistent
Serial number and firmware number would be appreciated but not neccessary.
Thanks for your help and I will report the results and reason if enough data comes in.
Ed Oliver
Test:
Ed Oliver
