Storing timelapse files
Maksim Bakulin
New member
TL:DR Is there a way of storing source timelapse files in efficient way with acceptable quality loss?
I occasionally shoot timelapses as a series of raw images using camera's built-in intervalometer, then I process them using Lightroom and LRTimelapse, export photos as jpeg and create a video using ffmpeg or Davinci Resolve (non-studio).
I want to have a chance to add some edits and/or crop later (say, year later I'd like to grade photos differently because my style/grading skill changed), so storing only jpeg or only resulting video is not enough, but storing hundreds of gigabytes of raw/dng files is painful.
I'd like to know what are my best options. I have a rough sketch, but no idea how to actually do it and what are best practices: convert all dng-s to a compressed video file, that will have some dynamic range and quality loss compared to dngs, but that should be acceptable, because in the end I usually export timelapses in FHD. What formats and codecs should I use? Say, use TIFF-16bit to export dngs as images from lightroom (to save initial grading), then convert these tiffs to a video file with h265 and 12 bit for color (if 12 bit for 265 is even a thing) and high bitrate. Will it preserve most of the information?
If JPEG doesn't cut it for you, quality-wise, your best option is probably saving the RAW files only. TIFF and DNG files are typically larger than the RAW. At least with my cameras.
And saving RAW means zero data loss.
