Since it isn't very friendly outside for macro photography, I figured I would try to improve my stacking skills. I'll preface this by saying that I am a complete novice when it comes to doing large stacks. I am hoping that some of you stacking masters can help improve my process.
We have a new orchid blossom opening so I set up the tripod and shot a large focus bracket using a focus differential of 3 on my OM-1 with my 90mm macro and flash. I ended up using 35 of the images in the sequence to cover a front to back distance of an estimated 8-10mm +/-. The last image below is my final stack. I am using Lightroom and Photoshop to do the editing.
My process is to import the raw files and increase texture and clarity in LR. I then select the images in sequence and export to PS to do the stack. In PS, I select the images and use edit>auto align layers>auto, then edit>auto blend layers>stack images. I do a very slight crop to remove misaligned edge and then export image from PS back to LR for final tweaking. I was disappointed with the final output file from PS since there were many blurred areas without detail in the white and yellow parts of the flower which I then had to very carefully manually fill in with editing in LR to get an acceptable final image.
So, since I am a self-taught novice in this aspect of photo editing, I am wondering if my process is correct and I have no clue. Are blurred out areas to be expected from stacking so many images with such fine low contrast detail as with the yellow and white parts of this flower? Do the blurred areas mean my focus differential was too large and I should reduce it to 1 or 2? Does other software perform stacking better than PS? Are the steps in my process lacking or wrong? Any help from experienced stackers would be appreciated.
