New to the X-T5. This camera is more like programming than the more primitive practices of M43 I have been shooting for the past years. I'm working on getting a handle on things and have some probably dumb questions.
I will be shooting in both AF and manual. Is there a way I can set up a custom setting that I can access with a minimal button clicking to reset my camera for manual shooting modes, most importantly to access the 'shoot without lens' setting? Is that something that the MY CAMERA is about?
You only have to set SHOOT WITHOUT LENS once and leave it on.
To switch to manual focus you just have to flick the front MCS switch to “M”
For manual exposure, there the isn’t an M on a PASM dial, you simply switch whatever parameter you want to control manually from “A” to whatever fixed value you want (nothing set to A = full manual mode.
If you don’t want to use the top dials for manual settings, there are also options to move control of the various parameters from top dials/aperture ring to the front and rear command dials - for example, I usually shoot in Aperture Priority with auto-ISO, so I set the aperture manually with lens ring (it can be switched to a command dial, but I prefer the ring), I set the top exposure comp. dial to “C” which shifts control to the front dial, my auto ISO Is usually set to A with one of the custom buttons assigned to quickly switch between the 3 auto-iso presets (primarily for setting the minimal allowable SS). If I want to force base ISO or set a particular ISO value, I simply rotate the dial from A to whatever fixed value i want to quickly override auto control as needed. The SS dial also sits at A which I can switch to a fixed value to override or, switching it to “T” mode transfers manual control to the rear dial. Since, in aperture priority mode, my EC control on the front command dials is in continuous control of both SS
and ISO fine-tuning, after choosing a minimum allowable SS with an auto-ISO preset, I just need to set my aperture as needed and fine-tune the SS/ISO with the front (EC) dial when necessary. This works for almost everything, but I can always simply move any of the top dials from A when I need manual control over any parameter. There lots of alternative ways to set up the camera to shoot, this is just how I do it.
I am used to setting focus by half-pressing the shutter and then composing my image. I noticed with the X-T5 that as I moved the framing - I lost focus on the target. Perhaps I am too conservative on how much pressure I am excerting on the shutter button? Yes I know I can use the focus lock - I am trying to get an overall sense of how the camera works. Whenever I search for info on that I get a string of videos all about back button focus. As I said, I want to know the perimeters of this camera.
With the SHUTTER AF menu option set to ON (separate options for AF-C and AF-S) half-pressing and holding the shutter button in AF-S will lock focus at that distance until you full-press (not alway accurate if you recompose). In AF-C you’ll want to try Wide Tracking - half-pressing and holding the shutter button will lock focus at the AF box position, but then track that spot as you recompose elsewhere. AF-S with the AF box pre-positioned where you want the focus point with a single full-press of the shutter button is typically the most accurate and reliable AF method, IMO, including with most predictably moving subjects.
I don’t recommend back button focus except in manual mode - “M” on the front dial (which I use all the time). This does not not require turning SHUTTER AF off (it’s automatically off in M mode)
I have hesitated asking this question here as it seems so basic and yet I am not finding that information in the form that is making sense to me.
Thanks.
Don’t worry about it. There are about a million ways to set up and use these cameras, it will take some time to sort through all the options to figure out what’s going to work best for you. I do recommend exploring all the possibilities rather than just trying to make it work like a previous camera you were used to. Once you get your head around the “classic” Fuji interface you’ll likely find it to be very intuitive, flexible and usable in any situation with only the external controls, without having to regularly dive into any menus.
