Thanks so much for the comparison. I do have to ask though. Your
SD9 image looks quite bad and not really the same quality I am used
to seeing. The images I'm getting out of the camera are way
sharper. I am also upsampling my images. I'm wondering if you had
something wrong with the lens or camera or if it was just the
compressed image online. It could have even been the upsampling.
There is just almost no detail in that shot which is what the SD9
is known for.
Hi. There is a big difference between fashion, product, portrait
and landscape shots, the former requiring less resolution than the
latter. I chose a landscape shot with an almost pure foliage
content because it is the most challenging for an imaging system.
(Think of the resolution you need to resolve all those pine needles
one hundred yards away!) I think what you're seeing is that even
3.54 true color megapixels is not enough for landscape use for this
particular type of shot. (I expect my tight field of view and
street shots to be much more favorable to the SD9. Also, keep in
mind that alough the crops may look quite different, the difference
is not as apparent in the print. That's why I discourage people
from making evaluations based entirely on lookinig at 100% crops.)
Michael Richeman, of the Luminous Landscape web site, no longer
uses his Canon 1Ds for landscape use. He has now moved
up to a
Contax 645 system with a Kodak 16MP DSC ProBack. So even the 1Ds
was found a bit wanting in resolution for landscape use. However,
your concern is noted. This weekend, when I take more comparison
shots, I will attempt to broaden my comparison images.
I would encourage you to download the two large crops. Open both
of them in Photoshop and view at print size. When you do that
you'll see that the two crops don't look that much different.
