No. You cannot assume picture quality from file size.If I use the old epson 1200u the file is 750kb
Phone gives 2.5 mb
Camera gives 5.5 mb. (Lumix )
Can I safely assume the camera gives the best results?
Using a film carrier / slide holder with a built in light behind it.
Most people I know get the best results using a device to hold the negatives flat that has a good diffused color neutral light source behind it. They then use a modern camera with a high quality lens on a tripod or copy stand and get exceptional results. Assuming the negatives are not dusty or damaged this works well with minimal post processing - although you need to deal with the color inversion which can be tricky but there are tools.If I use the old epson 1200u the file is 750kb
Phone gives 2.5 mb
I’ve been out of scanning for something like 20 years, but what is nowadays a good tool for color reversal?Most people I know get the best results using a device to hold the negatives flat that has a good diffused color neutral light source behind it. They then use a modern camera with a high quality lens on a tripod or copy stand and get exceptional results. Assuming the negatives are not dusty or damaged this works well with minimal post processing - although you need to deal with the color inversion which can be tricky but there are tools.If I use the old epson 1200u the file is 750kb
Phone gives 2.5 mb
Several people I know say that darktable with negadoctor works well.I’ve been out of scanning for something like 20 years, but what is nowadays a good tool for color reversal?Most people I know get the best results using a device to hold the negatives flat that has a good diffused color neutral light source behind it. They then use a modern camera with a high quality lens on a tripod or copy stand and get exceptional results. Assuming the negatives are not dusty or damaged this works well with minimal post processing - although you need to deal with the color inversion which can be tricky but there are tools.If I use the old epson 1200u the file is 750kb
Phone gives 2.5 mb
The Epson Perfect 1200U is a very old flat bed scanner with a maximum resolution of 1200ppi (around 1.9MP for 35mm). For scanning negatives now something like an Epson V850 would give a true optical resolution of ~2200ppi (around 6.3MP), a Plustek 8200 film scanner up to 3500 ppi (around 16MP).does all this make sense to anyone- re negatives/slides?
Your EPSON Perfection 1200U scanner includes the following features:
■ Superior image quality:
■ True optical resolution of 1200 dots per inch (dpi)
■ Hardware resolution of 1200 × 2400 dpi
■ Maximum resolution of 9600 × 9600 dpi with interpolation
■ 36-bit color depth for capturing images with over 68 billion colors
■ EPSON TWAIN for high speed scanning and accurate optical character
recognition (OCR)
■ Start button for one-touch scanning
■ Letter/A4 size scanning area (legal size documents can be scanned with the
optional auto document feeder)
■ Optional transparency unit and auto document feeder
thanks all
A while ago I posted a number of programs / methods to do this inversion ( https://www.dpreview.com/forums/post/65862649 )I’ve been out of scanning for something like 20 years, but what is nowadays a good tool for color reversal?Most people I know get the best results using a device to hold the negatives flat that has a good diffused color neutral light source behind it. They then use a modern camera with a high quality lens on a tripod or copy stand and get exceptional results. Assuming the negatives are not dusty or damaged this works well with minimal post processing - although you need to deal with the color inversion which can be tricky but there are tools.If I use the old epson 1200u the file is 750kb
Phone gives 2.5 mb
There’s some info on the SilkyPix website (I’ve never used it myself) - https://www.silkypix.com/en/how-to/article/function/1655/I have silky pix for raw- will have to look at it again!
thanks
I don’t know about the FX2500 - you really need a good macro lens, a way of firmly holding the film and camera and a good light source. Most people who use cameras use DSLRs or ILC mirrorless rather than bridge cameras.so a modern lumix FZ2500 is probably better?
thanks
In this review of the Digitaliza ( https://www.35mmc.com/18/07/2022/lomography-digitaliza-max-review-by-george-griffin/ ) the author said that he needed to zoom by a factor of three for 135 film. Of course a modern mobile phone often has a zoom lens of around that so there might not actually be too much pixel loss.Forget the phone. Phones cant get close enough to properly focus, so you end “zooming” digitally of course.
I don’t think the OP wanted to use a DSLR, rather a bridge camera, so there wouldn't be the possibility of using a dedicated macro lens.The best results are a matter of technique and software too.
To properly scan a neg without losing detail, you need at least a 24MP DSLR, a proper macro lens capable of 1:1 reproduction ratio, and a carrier that holds the film flat.
Then you need the right software too. You can do it manually with Photoshop or similar or buy plug-ins.
But, yes, the DSLR would give the best results, but not because the file size is the largest.
