Software License Agreement | Digital Camera | Digital AV | Support | Panasonic Global
- Support for RAW video output via HDMI to ATOMOS recorders has been added.- [8.1K(3:2)], [8.1K(17:9)], [7.2K(3:2)], [5.7K(17:9)], and [4.8K(4:3)] 12-bit RAW video data can be output over HDMI.- The ATOMOS HDMI field monitors/recorders "NINJA V+", "NINJA V", "NINJA", "NINJA ULTRA", "SHOGUN", "SHOGUN ULTRA", and "SHOGUN CONNECT" allow for recording in Apple ProRes RAW.* This does not guarantee all performance capabilities.* "NINJA V+", "NINJA ULTRA", "SHOGUN ULTRA", and "SHOGUN CONNECT" support all video RAW data. "NINJA V", "NINJA", and "SHOGUN" do not support certain video RAW data.* To edit video RAW data recorded with ATOMOS recorders, software that is compatible with Apple ProRes RAW is required.* If you wish to edit video RAW data with the same color tone as V-Log/V-Gamut, please use the LUT available on the support site below.
https://panasonic.jp/support/dsc/download/lut/s1h_raw_lut/ - Support for RAW video output via HDMI to Blackmagic Design recorders has been added.- [8.1K(3:2)], [8.1K(17:9)], [7.2K(3:2)], [5.7K(17:9)], and [4.8K(4:3)] 12-bit RAW video data can be output over HDMI.- The Blackmagic Design recorders “Blackmagic Video Assist 5" 12G HDR” and “Blackmagic Video Assist 7" 12G HDR” allow for recording in Apple ProRes RAW.* This does not guarantee all performance capabilities.* When recording in 8.1K (3:2) 24p, 8.1K (17:9) 30p/25p, 7.2K(3:2) 30p/25p, 5.7K 60p/50p or 4.8K 60p/50p, constant bitrate 5:1 or less is recommended for SSD recording and 8:1 or less for SD card recording.* DaVinci Resolve or DaVinci Resolve Studio is required to play back and DaVinci Resolve Studio to edit Blackmagic RAW data.
- Compatibility with DJI gimbals has been improved.- Bluetooth connectivity has been enabled for use with DJI gimbals.* This does not guarantee all performance capabilities.** Click here for information on verified operation of the gimbal.
- Compatibility with "Capture One" has been improved.- Wi-Fi connection with "Capture One" and wired LAN connection using a USB Ethernet adapter are now supported.* This does not guarantee all performance capabilities.** Click here for information on verified operation of the USB dongle.
- Timecode Sync functionality with external devices has been added.- Bluetooth connection with ATOMOS UltraSync BLUE now allows for timecode synchronization.* This does not guarantee all performance capabilities.
- Feature addition via upgrade software key "DMW-SFU3A"- An [Activation] feature has been added to enable extended functions using the separately sold upgrade software key "DMW-SFU3A." By performing "Activation," the [Photo Style] [ARRI LogC3] will be added.
- Video quality options for recording in [MOV] have been added.- Added video quality options for [8.1K (3:2)] and [7.2K (3:2)].
- Internal proxy recording function added for HDMI RAW Output.- It is now possible to simultaneously record low-bitrate proxy videos during HDMI RAW output.
- HEIF format has been added.- Added HEIF image recording format (.HIF).- HLG shooting in HEIF format is now supported.
- AF Recognition has been enhanced.- "Urban Sports" recognition has been added to the automatic recognition targets.
- Focus stacking feature has been added.- Deep-focus images can now be generated by compositing images taken at multiple focal points.
- Enhanced Image Copying Function- It is now possible to copy files recorded on an SD card/CFexpress card directly to an SSD.
- Improved Focus Ring Operability for Interchangeable Lenses- A preferred function can now be assigned to the focus ring.- The rotation direction of the focus ring (clockwise/counterclockwise) can now be set.- Lenses compatible with this function are required.
Click here for confirmed operation information on compatible lenses. - Enhanced Pixel Refresh Function- An option to automatically perform pixel refresh has been added to the menu.- This will be automatically set to ON after the firmware update. The mechanical shutter will operate while the pixel refresh is in progress.- Pixel refresh function runs automatically on first power-off after the firmware update.
- Other enhancements- The color of the AF frame can now be changed.- The frame marker function has been enhanced (up to three frame markers can now be displayed at the same time).- UVC (USB Video Class) standard compatibility has been added.- Compatibility with OM Digital Solutions Co., Ltd. flash units has been improved.- Support for enhanced functions of LUMIX Flow (Ver.1.2) has been implemented.* Click here for details on function enhancements.
- When certain video quality settings are applied, the cropping range during live crop shooting has been adjusted to reduce processing load on the camera.- Other improvements have been made to enhance operational stability.
