I have recently started scanning and cataloguing 3 generations of photos. Of course, the oldies are all black and white and it is predominate into the mid-70s. It is all prints - negatives were tossed at some point.
I am using an Epson flatbed scanner with the Epson software. For 80% of the photos, this is good enough for the family history. But, for 1 in 5, the quality of the composition or the subject matter, I want to increase the quality - primarily removing scratches, speckles and other blemishes and, for some, improve the lighting as they are quite dark.
I have Paintshop Pro 2023 so that is my tool of choice. I am often happy enough with the results - but sometimes the result almost looks worse than the original with a lot of blurriness and small artefacts.
Being new to editing, I am sure my approach and workflow can use improvements (and may change my "happy enough" to "very happy". For those prints, I decide to invest time in editing, I do the following:
1. Scan to TIFF 24 bit color with all scanner settings turned off
2. Scan at 600, 800 or 1200 dpi depending on the size of the original (smaller = higher resolution)
3. The sequence in Paintshop is:
a. Crop and/or straighten
b. Apply automated despeckling to the whole image (when warranted)
c. Manually use a healing and/or clone brush for remaining blemishes
d. Adjust lighting (when needed)
e. Sharpen - usually the whole image, but occasionally just faces.
f. Save a copy as a greyscale JPEG to share
I will appreciate any and all commentary, suggestions and questions.
