Karl_Guttag
In a prior topic, I compared the R5m2 scaling to the R5's IBIS on a high-resolution test pattern that would cause more. The prior analysis showed the problem of rescaling a HEIF (or JPEG), which is that you have already lost a lot of "information" from the RAW file. But I know people will say, "what about a "real" picture?"
I tried to set up a "typical" person shot, a person in a group, or a portrait full-body shot. (Before this, I tried a headshot with a much bigger eye. There was almost no difference between the same scaling methods, as the eye and eyelashes were big enough that the scaling method was not much of a factor).
It was a quick and dirty setup to get a representative picture of my eye (using the R5m2's eye tracking). The picture below is to show framing and sizing, so I have blurred out the background and resized the whole image. Its not a great setup, but I only wanted the image of the one eye.
Picture to show framing with the eye shown in the red rectangle
The matrix below shows various scaling methods. I have scaled everything to the same size. The Original picture was taken with RAW. I covered the RAW to HEIF with the HEIF quality set to 10 (best). There are three areas that stand out: the eyebrows, eyelashes, and IRIS. The description of the rows is as follow:
Conclusions:
Theoretically and based on my testing, the R5m2's in-camera scaling is worthless for anything other than making an image bigger. It has been so far to eliminate IBIS High Res and try and substitute this abomination. Hopefully, Canon will, as they did with the R5, add IBIS HR with a firmware update (and save the multiple RAW files rather than a single JPEG)
Almost any decent scaling program on a computer could do better, and an upsizer works from RAW, it would be much better. The fact that the scaling only works from JPEG or HEIF makes it ridiculous to put it "in camera." Frankly, even if the in-camera works from RAW files, it would be better done with a PC.
Working from the RAW file retains some "information" in the image that is lost when the image is deBayered/converted. This extra information helps with upscaling, so it is better to upscale directly from the RAW.
- For the HEIF, I have enlarged it by pixel replication (just to make the pixels bigger) and using Photoshop Bicubic scaling. You can see how the eyebrows are both lost and take on a pixelated/jaggy effect. The IRIS has lost resolution, and some of the eyelashes are all but gone.
- This row has the R2m2 in-camera upscale from the HEIF and a simple bicubic enlargement followed by an Unsharp Mask with a radius of 1.5 at 100%. I find it very difficult to tell the difference between the two pictures.
- Note that not only is all the detail in the eyebrows lost, but there are some jaggy artifacts.
- The eyelashes are blotchy and some of all but missing
- There is a lack of detail in the eye
- This row shows Photoshop Super Resolution from the original RAW file (ACR "enhance Super Resolution" works on the R5m2 CR3 files).
- There is a dramatic improvement in the eyelashes over the R5m2 in-camera scale
- There is more detail in the eyelashes
- There is detail in the ISIR not seen in the in-camera scaling
- Adobe Camera RAW is noisy and the USM sharpening enhances that noise.
- This row shows PS bicubic scaling from a RAW file (left) and USM r1.5 100% sharpening on the right.
- The eyebrow detail is lost (about the same as the in-camera scaling)
- The eyelashes are between the in-camera scaling and Adobe Super Resolution.
- The Iris looks similar to the Adobe Super Resolution and is much more detailed than with the in-camera scaling.
Conclusions:
