Karl_Guttag
A few things I found with the new firmware were small surprises. Perhaps it would be a good idea to save your settings before doing the firmware update (I didn't).
Nothing life-threatening, but after upgrading my R5m2 to firmware 1.1.1, I noticed that my Quick Menu ("Q" button) had been changed. Most notably, it wiped out the flash card settings menu (which takes up two spots).
For those that don't know, you can customize your Quick menu. This video explains how to do it:
Note that you must have two slots on one side of the menu to enable the Flash Card settings on the Quick Menu. The video linked to above shows how you can move them around by hitting the "info" button.
I also noticed that the update seemed to replace My Menu 1 with some things. Once again, this is a small annoyance. I need to remember what was there and decide what I want on that menu.
One nice feature is that if you have the Pre-Shooting option in your quick menu, clicking on it includes both enabling/disabling Pre-Shooting, as well as setting the amount. Unfortunately, when PRE is in the Quick menu, it only allows you to enable/disable, without the option to set the amount to pre-shoot. While nice to have the "PRE" option in the Quick Menu, it seems redundant to have to hit the button and then hit enable/disable rather than working as a toggle itself.
