alecspra25
New member
- Messages
- 5
- Reaction score
- 1
When I convert a color image to black and white I dont bother trying to get the color balance and saturation right before converting it. The reason is that I have found that by the time i settle on the black and white image that I like, the underlying color image usually looks awful. So i have always been puzzled by claims that say you need to get your colors right before converting.
To be clear, what I do is process the 32 bit color raw image to correct for chromatic aberration, distortions, and luminosity values, and sometimes tone mapping. Then I convert the image from 32 bit to 16 bit. AT that point I add a black and white adjustment layer above the color image, and tweak the color channels until I get within the ball park of what I like. Then I add a white balance adjustment and saturation layers underneath the black and white layer, then tweak those 2 layers to refine the look I want in the black and white image. Then I may add a levels and possibly additional adjustment above the black and white layer, and tweak those until I get the final look I like.
At that point if I turn off the black and white adjustment layer and look at the color image result underneath, it usually looks awful.
So I dont understand the point of trying to get the colors right before using the black and white adjustment layer. From my perspective, it sounds like a waste of time.
Does that make sense to you? Do you use a similar approach? Am I missing something here?
