Rob de Loe
I've been peripherally aware of Qimage for many years, but never looked at it until today. When I was printing black and white with Epson printers, I used Quadtone RIP and a custom monochrome inkset -- so it wasn't even an option. Since switching to the Canon Pro-1000, I've gone back and forth between Lightroom's print module, and Canon Professional Print and Layout (CPPL). Both seemed fine.
In a recent thread on native printer resolution, Qimage came up a few times, always positively. So today I downloaded the 14-day trial version of Qimage One for Windows. Note that this is not Qimage Ultimate, but the same developer is involved; apparently it's a streamlined version that focuses on printing.
To cut to the chase, if you're using something else, you should try Qimage One. I haven't put my money down for a license yet (lots more testing to go), but if I keep getting the results I've gotten so far, I probably will.
The Test
I made three prints with image areas of 11" x 15.5" on Epson Ultra Premium Presentation Matte paper on a Canon Pro-1000. I use this paper for testing and drafts. If there's detail, it will hold it very well, for a matte paper.
The three prints were made using Lightroom's Print module; Qimage One for Windows (via Lightroom plugin); and Canon Professional Print and Layout (CPPL) via Lightroom plugin.
The test image I used has lots of detail everywhere, which helps in a comparison like this. There are also some areas where details are in deep shadows; getting those right is especially important for black and white.
Test image. Fuji GFX 50R on my Toyo VX23D. There's loads of fine detail in every part of the image that isn't sky or moving water.
For each of the three prints, I tried to keep everything similar or the same to make it a fair comparison:
I was going to make some pictures to compare the prints, but that almost never works well. So you'll have to take my word for these initial results.
Detail/Sharpness
Tones
Yes, I use a calibrated workflow.
I appreciate that Qimage One and CPPL got me much closer to what I see on my screen. Before I get too excited, I need to do more testing, but I'm curious if anyone else has noticed what I'm seeing.
Setup and ease of use
All three have quirks and annoyances. Pick your poison. I could use any one of them, just with different grumbles.
No firm conclusions yet... This post is a conversation starter rather than a conclusive review.
I will say that if you haven't tried Qimage One (for Windows or Mac), it's worth a look. So far, I'm impressed.
The Test
- Same driver settings
- 600 dpi in Lightroom and Qimage; "finest quality" in CPPL. There's no setting for dpi that I can see, and this option was locked in.
- Black and white mode selected in the Canon driver.
- Black and white mode explicitly selected in CPPL (which allows this); "Printer manages color" in LR and Qimage (which means black and white mode via the driver).
- Sharpening set to Default (5) for Qimage; Standard for matte paper in Lightroom; and whatever Canon Professional Print and Layout uses because there doesn't seem to be a setting to control print sharpening
- No fiddling with contrast at the print stage in Lightroom, or in the other tools.
Detail/Sharpness
- Qimage did the best job with the details. If there was something to see in the original, it was more present in the Qimage print than in the others. Qimage recommends the default setting for most prints, and they're not wrong.
- Lightroom's standard sharpening for matte paper was close to Qimage for preservation of detail. I suspect it could be even closer to Qimage than these prints show, but that it looks worse because of the shadow problem (below).
- CPPL was clearly the worst. It's far from terrible, but areas that showed detail in the other two prints were softer in the CPPL print. Is there an output sharpening setting in CPPL that I'm missing?
Tones
- Lightroom crushed my shadows. If Lightroom was my only choice, I'd have to boost the shadows before printing to get it back to where it needs to be to look like what I see on my calibrated screen. This was surprising.
- CPPL and Qimage both did a good job of producing a print that looked like what I'm seeing on my calibrated screen. However, I still give it to Qimage because that print seems to match what I see on screen just a bit better overall.
- I find Lightroom the least intuitive. I realize that's just me. Lots of people love the design of the print module.
- CPPL, launched from Lightroom, is generally understandable, and has a few features I quite like (especially the ability to do toning). I think it should be easier to define the size of the printed area, and where are those sharpening settings?
- Qimage One for Windows reminds me of late 1990s Windows software. Ugh. However, if you can get past that, the overall design is solid. I like being able to specify the size of the paper and the size of the imaged area. The ability to put multiple images on one sheet is a huge plus.
