Potentially handy new feature for this particular forum
Billiam29
Chicago, US
I just wanted to point out a new feature for those that may be unfamiliar with Xenforo forums and their bretheren. Specifically, the ability to use the code and icode tags.
The code tag will place the text you enclose with it into a fixed width uniform text block. See example #1 below.
The icode tag will format the text you enclose with it like the code tag, but keep the text inline with the paragraph you are typing. I have used the icode tag when mentioning the tag names in this post. Example number #2 below is another more computer-relavant example.
Example #1 (code tag)
The driverquery command is often overlooked, but can provide a wealth of information.
Code:
Module Name  Display Name           Description            Driver Type   Start Mode State      Status     Accept Stop Accept Pause Paged Pool(bytes) Code(bytes) BSS(bytes) Link Date              Path                                             Init(bytes)
afunix       afunix                 afunix                 Kernel        System     Running    OK         TRUE        FALSE        24,576            8,192       0                                 C:\WINDOWS\system32\drivers\afunix.sys           4,096
ahcache      Application Compatibil Application Compatibil Kernel        System     Running    OK         TRUE        FALSE        180,224           20,480      0                                 C:\WINDOWS\system32\DRIVERS\ahcache.sys          4,096
amdgpio2     AMD GPIO Client Driver AMD GPIO Client Driver Kernel        Manual     Stopped    OK         FALSE       FALSE        4,096             12,288      0          2/7/2019 3:32:20 AM    C:\WINDOWS\system32\drivers\amdgpio2.sys         4,096
amdi2c       AMD I2C Controller Ser AMD I2C Controller Ser Kernel        Manual     Stopped    OK         FALSE       FALSE        4,096             36,864      0          3/19/2019 11:57:33 PM  C:\WINDOWS\system32\drivers\amdi2c.sys           4,096
AmdK8        AMD K8 Processor Drive AMD K8 Processor Drive Kernel        Manual     Stopped    OK         FALSE       FALSE        106,496           57,344      0                                 C:\WINDOWS\system32\drivers\amdk8.sys            8,192
AmdPPM       AMD Processor Driver   AMD Processor Driver   Kernel        Manual     Stopped    OK         FALSE       FALSE        106,496           57,344      0                                 C:\WINDOWS\system32\drivers\amdppm.sys           8,192
amdsata      amdsata                amdsata                Kernel        Manual     Stopped    OK         FALSE       FALSE        0                 61,440      0          5/14/2015 7:14:52 AM   C:\WINDOWS\system32\drivers\amdsata.sys          4,096
amdsbs       amdsbs                 amdsbs                 Kernel        Manual     Stopped    OK         FALSE       FALSE        0                 229,376     0          12/11/2012 3:21:44 PM  C:\WINDOWS\system32\drivers\amdsbs.sys           4,096
amdxata      amdxata                amdxata                Kernel        Manual     Stopped    OK         FALSE       FALSE        8,192             4,096       0          4/30/2015 7:55:35 PM   C:\WINDOWS\system32\drivers\amdxata.sys          4,096
AppID        AppID Driver           AppID Driver           Kernel        Manual     Stopped    OK         FALSE       FALSE        94,208            28,672      0                                 C:\WINDOWS\system32\drivers\appid.sys            4,096
AppleKmdfFil Apple KMDF Filter Driv Apple KMDF Filter Driv Kernel        Manual     Stopped    OK         FALSE       FALSE        4,096             4,096       0          5/7/2018 11:16:38 PM   C:\WINDOWS\system32\drivers\AppleKmdfFilter.sys  4,096
AppleLowerFi Apple Lower Filter Dri Apple Lower Filter Dri Kernel        Manual     Stopped    OK         FALSE       FALSE        4,096             16,384      0          5/7/2018 11:16:38 PM   C:\WINDOWS\system32\drivers\AppleLowerFilter.sys 4,096
applockerflt Smartlocker Filter Dri Smartlocker Filter Dri Kernel        Manual     Stopped    OK         FALSE       FALSE        4,096             4,096       0                                 C:\WINDOWS\system32\drivers\applockerfltr.sys    4,096
Example #2 (icode tag)
You can check the status of Bitlocker on your drives by typing manage-bde -status from an elevated commang prompt.
This is a great feature point out! May I move this thread to a more prominent forum section to share it with the rest of the community?
Sure. You're welcome to move the thread if you think it would benefit the overall forum community. I only posted here in PC Talk because I thought the formatting feature was most likely of use for computer related things.
BTW - If you're able, feel free to remove the word "particular" from the tread title when you move it. It might read a little better for the wider general audience.
Still can't post HEIC, however.
On the plus side, the forums look much like before, with typeface large enough to actually read.
