Colin Creevey
- Messages
- 1,392
- Solutions
- 2
- Reaction score
- 427
Hi all,
I am re-thinking my location kit and looking for some feedback about my thoughts regarding the setup for my key. The purpose of this kit is for taking portraits (upto full body) in a urban environment. Due to my disability, I will always have my gear cart with me which is has the interior dimensions of 49.5" L x 18" W (125cm x 45cm ).
I am looking for a setup that makes setting up and tearing down the light as fast as possible without giving as much focus to the weight of the setup.
For modifier I am thinking of getting a new octa box with a flip fold design. Something similar to the Glow ParaSnap 44" Octa. I've seen a 60" octa with the same design but already having a 60" I know what a pain that would be. Instead I was thinking of getting a 47" of the same design. If not I could look at the Glow 44" or a 36"
For my light I am thinking of either getting an AD300 or using my AD600Pro with extension head. If using the AD600 I could use a super clamp to clamp the body to centre column.
I have had limited experience with C-stands and all of that experience was in studio. If using my cart, I am wondering if a C-stand is going to be cumbersome. Specifically I was thinking of getting a Kupo 30" c-stand with turtle base (no leveling leg). The max height of this is 89" (226cm). Due to the size of my cart, this would mean removing the turtle base but I should be able to flip the softbox down and leave the light attached.
I already own some flat pack Manfrotto aluminum stands (1005BAC) that have a max height of 9' / 274.3 cm. However, while I am happy having an AD300 on top of this, clamping an AD600 to the central column is not a great idea as it is easy to damage the column with the clamp. Regardless which stand, I will be using a sand/shot bag.
Questions in summary:
1. Which size octabox do you feel would be best and why?
2. Should I look at getting an AD300 (no other uses for it) or just use the 600?
3. Which stand option do you feel is best?
Thank you in advance. I know my questions are lengthy but I rather type it out than people answering without context.
