Hi everyone, asking for your help here with the OM Workspace not working after I updated my Mac to Sonoma (MacBook Pro 16", 2023 Chip Apple M2 Pro macOS Sonoma 14.6.1).
After the update, it keeps asking for the extension to be enabled:
System Extension Blocked
A program tried to load new system extension(s) signed by "OM Digital Solutions Corporation". You can enable these extensions in Privacy & Security
System Settings.
I have already tried to follow these steps but with no luck.
I have the same problem with Paragon NTFS but I managed to solve it following step 4 here and command
If you receive an error, or the problem persists, please try to reset pending KEXT library. To do so,you need to know the Volume Name of your macOS Volume. It can be checked using this command:
diskutil apfs list
check the Name of the volume with the System Role (for instance, Macintosh HD).
Boot into Recovery Mode
Execute the following command in Terminal:
kmutil trigger-panic-medic -R “/Volumes/SystemVolumeName“
where SystemVolumeName is the volume with the system role from “diskutil apfs list” command
(for instance
kmutil trigger-panic-medic -R “/Volumes/Macintosh HD”)
Reboot as usual, then check if it’s now possible to Allow our extension.
However, after allowing Paragon the problem is still there with the OM Workspace asking to be enable.
At this point I tried to uninstall OM Workspace manually deleting also all the possible leftovers + also trying Cleanmymac X but the problem is still there, OM Workspace is still listed under system settings -> privacy & security.
Also, I don't have any "allow" option, just the "details" one. If I select it it shows the screenshot here above but the toggles don't work.
To be able to see the allow option I need to go back into recovery mode and command kmutil trigger-panic-medic -R “/Volumes/SystemVolumeName“. After that, I can see the allow button but allowing everything doesn't work, after restarting the Mac I am just left in the situation as shown in the screenshot here above (OM asking to be enabled, no allow option, no toggles).
I also tried to disable SIP but again no luck as I get the error:
-bash-3.2# csrutil disable Turning Systen Integrity Protection requires modifying system security. Allow booting unsigned operating systems and any kernel extensions for 0s "Macintosh HD? [y/n]:y
Enter password for user: *****
Icsrutil: Failed to update security configuration for "Macintosh Failed to create paired recovery local polícy -bash-3.28
Trying csrutil clear it says
-bash-3.2# csrutil clear
Enter password for user *****
csrutil: failed to clear system integrity configuration: Failed to create paired recovery local policy
-bash-3.2#
Is there a way of getting rid of the OM completely and/or solve this problem? Only option I am left with at this point is formatting the Mac but I'd like to avoid that if possible.
Thank you!
System Settings.
diskutil apfs list
(for instance
-bash-3.2#
Thank you!
