abgestumpft
Forum Enthusiast
- Messages
- 436
- Reaction score
- 675
I have done some intensive testing on OM-1 Video the past days. For this test alone of comparing the different modes (codecs, framerates, resolution,…) I've shot 81 clips in different settings.
General findings:
-Shutter button does not work for AF in Video (seems to have no function at all)
-AF-ON can be assign to a button, but it will then focus with "hunting" -> can be used for initial AF before Video is started. During Video it's better to use the touch AF -> this will do a smooth transition.
-Object AI AF can be used in Video, but only when AF is set to C-AF+TR. When Video recording is started, there are two different behaviors, depending on Setting: AF->2.AF->AF Area Pointer:
1. On1: when Video recording is started, the white box around the object will be replaced with the green box we know from the C-AF+TR of the other Olympus cameras
2. On2: when Video recording is started, the white box around the object will disappear. But you will see the small green AF Boxes were it focuses on.
-I have not yet tested the AI AF in Video -> to be seen if it works as good as in Photo mode...
-Video Mode can NOT be assigned to a custom mode (C1-C4)
-I was able to set a custom target mode, but I'm not able to select it in Video mode -> here I only can select four standard target modes.
Wrong bitrates:
-Bitrates shown in camera of all SlowMo modes are wrong (see last image in this post)
-Bitrate of FullHD h264 ALL-I seems to be wrong too (102Mbps instead of displayed 202Mbps)?
Image quality:
-Most 4K/C4K modes (all h264 and h265@152Mbps - 50/60 fps) look very similar (in terms of detail) to EM1.3 4K 30p 102Mbps
-there is no difference in details between C4K and 4K (like it was for EM1.2/EM1.3)
-4K/C4K h265@77Mbps - 24/25/30fps look noticeably more detailed than all other 4K/C4K modes -> maybe a little better than EM1.3 C4K. So 4K h265@30fps - 77Mbps looks more detailed than 4K h265@60fps - 152Mbps.
-all HD modes (except SlowMo) look very similar in terms of Detail (h264/h265 - LongGOP/ALL-I - …)
-all HD SlowMotion modes also look very similar to each other and have less detail than the normal HD modes (and have a slight crop vs normal HD modes)
-IS1 (Sensor + Digital) does a crop and image Quality looks almost as good as IS2 (Sensor only). 4K h265@30fps IS1 (Sensor + Digital) looks better than 4K h265@60fps - 152Mbps IS2 (Sensor only)
High Framerate thoughts
-Not sure why the 60fps/50fps modes in h265 don't look as detailed as the 30fps modes. Maybe processor is not fast enough for video processing at those speeds?
-Also: why is there no 4k @120fps -> we get this in foto RAW
-Why is the image quality in HD@120fps not as good as 60fps HD (can't this even be down sampled from 4K/120p?)
-If my math is correct, the Sensor should be able to do 1920x1440 @ 320fps (via crop 1:1 pixel readout)
Zebras/Histogram
-min. Zebra setting is 80 -> cannot be used for skin tones. Wish there was 60 and 70 too.
-Max Zebra setting is 109 -> works well as overexposure warning in HLG and OMLog400: When Zebra 109 in HLG/OMLog400 shows clipping on OM-1 screen the final Video will also show clipping there.
-Histogram changes when enabling "View Assist" in OMLog400 mode (gets stretched). But still works to judge the exposure: also here highlights clip at the same time.
HLG vs OMLog400 (in h265 10bit)
-Both seem to have the same dynamic range
-OMLog400 always needs to be graded (for SDR and HDR)
-HLG looks excellent out of the box on HDR screen supporting HLG (should be 4K TVs staring 2018)
-It is also said that HLG should look good on SDR screens, but I don't agree with that: While brightness is OK (still a bit too dark though) the colors are flat and especially the shadows have a greenish tint -> e.g. also faces look strange…
-But HLG can be graded to SDR e.g. in Davinci Resolve Studio
-I did some testing with grading to SDR of HLG and OMLog400 in Davinci Resolve Studio and found that both work well (did not see a disadvantage for HLG being a broadcasting format here). BUT: I'm not an grading expert!
-OMLog400 and HLG have different Gamma curves (did not find details on this), so one might have the advantage over the other in highlights or shadow work
-Image preview on screen of HLG looks a little like OMLog400 with "View Assist" on (midtones a little darker and shadows a little brighter)
-Autoexposure and Auto WB work well in HLG and OMLog400
Conclusion so far:
The most detail is with 4K/C4K h265@77Mbps - 24/25/30fps (in HLG or OMLog400). Since HLG looks great on TV out of camera and I'm able to grade HLG in Davinci Resolve to good looking SDR I will now be shooting in:
4K h265@77Mbps 30fps HLG. I have set Zebras to 109 to judge where highlights will be blown out.
I also prefer the overall look of the h265 (HLG and OMLog400) graded footage: it looks more natural than the h264 with Picture Profile.
Here some screengrabs:
HD SlowMo Clips were taken one day later.
EM1.3 - 4K - h264 - 30p - 102Mbps
EM1.3 - C4K - h264 - 24p - 237Mbps
OM-1 - 4K - h264 - 30p - 102Mbps
OM-1 - 4K - h265 - 30p - 77Mbps - HLG graded to SDR
OM-1 - 4K - h265 - 60p - 152Mbps - HLG graded to SDR
OM-1 - HD - h265 - 30p - 22Mbps - HLG graded to SDR
OM-1 - HD - h265 - 200p to 25p SlowMo - 22Mbps - HLG graded to SDR
Wrong Bitrates in ALL SlowMotion modes in OM-1
General findings:
Wrong bitrates:
Image quality:
Zebras/Histogram
Conclusion so far:
