I am setting up my new Lenova 5i.
I want to change the "Documents" folder in Explorer quick access to a local folder. I don't want to use OneDrive.
I keep getting the "The folder cannot be moved" error.
I have unlinked and deleted OneDrive from the computer, still the same.
Any recommendation?
Check if OneDrive has already moved Windows personal folders (Documents, Pictures, Music) into its OneDrive folder. Path is: C:\Users\UserName\OneDrive.
As far as I know, if any of Windows personal folders are in the OneDrive folder, then they cannot be moved back to their original locations since you unlinked and deleted OneDrive. (If OneDrive was still installed and running, then it's possible to move those personal folders back to their original locations.)
But if you don't store any data in the Windows personal folders, then no problem. You can just leave them in the OneDrive folder. Just create your own personal folders and use them instead. For example, if you have a D data drive, you could create folders in it and use names like ~Documents, ~Pictures, ~Music. The leading tilde character will indicate that those folders are your own local folders and not the default Windows personal folders.
You can delete links and add links in Quick Access to suit your desires. I deleted links in Quick Access that I don't use, and put links in Quick Access that point to folders in my D drive. Very handy to have those D drive links in Quick Access, in many ways.
