matander
Forum Enthusiast
Amused myself with colllecting info from diferent K20D rumour threads, below is my summary.
14 Mp CMOS APS-C sensor, probably a Pentax design. Not Sony, Fujitsu, Kodak or Foveon.
Better DR than K10D
Improved SR
AF fine adjustments
Frame rate (from other forum) 1-2 fps behind competitors. Probably 4 fps (my guess).
Similar body as K10D, stainless steel + plastic, compatible with K10D BG2 grip.
Live view in LCD, larger, wide viewing angles, probably 3'
14 bit RAW
P-TTL flash (no TTL support)
PC sync connector
Lens mount same as K10D, still ”crippled”
+ lots of more features??
There have been no leaks on updates on the AF system, although it seems to be one of the most wanted upgrade in terms of lowlight performance, speed and CAF tracking performance.
24 jan 2008 will be an interesting date.
Mats
Better DR than K10D
Improved SR
AF fine adjustments
14 bit RAW
PC sync connector
Mats
