thomatkinson
Member
- Messages
- 48
- Solutions
- 1
- Reaction score
- 3
Hi everyone,
Has anyone ever had a problem with audio interference caused by LED video lighting?
I’m using a Sennheiser MKE600 microphone (battery powered) with a Canon R5. It sounds great, until I turn on my Nanlite Forza 500 (mains powered). A sort of electrical static interference noise turns up on the recorded audio and can be heard over monitoring headphones during recording. It gets worse if the power on the light is turned up. And it stops when I turn off the light. It doesn’t happen with the R5s onboard mic or with a Rode Stereo Mic Pro.
I’ve tried the following with no success:
- turning off fan on Forza 500
- Moving Forza head and ballast away / into a different room / behind a closed door
- with and without XLR lead
- with and without high pass filter on mic
- with and without mains extension cable / different circuits in different rooms
- with and without headphones or video monitor plugged in
- reducing mic levels to about 25%/30% on the R5 obviously reduces the noise, but doesn’t eliminate it.
Any ideas? Maybe I need different / better shielded cables (though I think they’re fairly decent ones)? Do I need a different mic? Would battery, rather than mains power for the Forza 500 help?
I’d be very grateful for any suggestions / experiences!
Thank you,
Thom
Thank you,
Thom
