I learnt the hard way last week that because the X30 only has a leaf shutter, it will not exceed 1/000 at the most open aperture even though the conditions require it. As I was unaware of this limitation, I hugely overexposed all pictures taken on a sunny day at the beach, with the dial set to A priority at f2.8.
I was so exasperated with the result from this otherwise beautiful camera that I promptly exchanged it for the XT10, with its choice of mechanical or electronic shutter, with which I am happy.
However, this still perplexes me: if I set the shutter speed manually to say 1/2000 at f2.8, if that gives the correct exposure, the camera will now ignore the 1/0000 limit and function normally. By setting the shutter speed manually, is it the case that the shutter will commence it's travel before the aperture begins to open, so all is well, whereas with the dial set to A mode the reverse is true. In turn, does this mean that in the brightest conditions you are obliged to remember to use shutter priority, or a smaller aperture, or EC, or some combination ?
If this is so, then although I was sorry to say goodbye to the X30, I know that I wouldn't have been happy with the uncertainty of which mode to use on any given sunny day.
I am JPEG only by the way.
