Got my M8 yesterday and have had some fun playing with it. I am
having difficulty reproducing deep reds (red roses are pink) even
when I exhaust my white balance options. Do I need a particular
temprature? This is more apparent on the monitor but is still a
bit soft on my computer. My D2 hits the mark with preset WB
without any difficulty. The images were correctable with CS but I
am concerned that I may have a problem. Thoughts?
Cameras with high infrared sensitivity (your M8, my old D100, the RD-1, etc) have this problem. Objects that reflect a lot of infrared light have additional magenta added to their color. Red flowers may not just go "pink", they may go "hot pink", a most annoying effect. Try explaining hot pink flowers to the mother of the bride....
Synthetic AND natural black fabrics, furs, and hair may go magenta.
Grass, trees, and the leaves of plants may go yellow...
You cannot fix these things with white balance. You can fix them in PhotoShop, but it's a lot of work, and very contrary to a Leica mindset. Shoot it right, up front.
The solution, as us DOTs (digital old timers) know, is a dichroic filter, often called a "hot mirror" or a "digital filter".
B+W 486 "Digital UV/IR Blocking" filters are great, a nice complement to Leica quality. The big problem is availability is horrible, except for small "SLR sizes" like 52mm, 55mm, or 58mm...
Heliopan "Digital Glass" filters are of comparable quality, and easier to get. Most of my IR contamination filters are Heliopan.
Expect about $110 each in sizes like 46mm for either Heliopan or B+W.
Tiffen "hot mirror" filters are less expensive than the German filters in small sizes. Tiffen also has a line of "digital clear" filters that are not dichroic filters, just clear glass to protect your lens from dirt and impact. Do not get the "digital clear" filters: if you buy a Tiffen, you need the "hot mirror".
Hoya makes something called a "digital filter" that is just a protective glass for your lens. It has no IR blocking capability. Avoid it. They also have a line of "digital" polarizers and "digital" close up lenses. Same thing, no IR blocking. Avoid those, too. Hoya makes nothing useful to the Leica shooter, unless you want to try infrared photography.
Normally, a signature this small can't open its own jumpgate.
Ciao! Joe
http://www.swissarmyfork.com
