John Friar
Active member
After reading about some of the benefits of converting RAW files to DNG, I went ahead and converted my existing Fuji XTrans files as well as now converting files on import.
So far, so good. I then did some digging around and stumbled upon this...
That thread is 2 years old, so I thought it best to start a new one! In short, and if I understand it correctly, converting .raf files to .dng will perform a demosaicing process resulting in a file that cannot take advantage of future improvements in XTrans processing. This didn't sound right.
I then downloaded RawTherapee so that I could take a peak at the .dng files after conversion/import. What I found, when viewing without any demosaicing applied, is that the original XTrans matrix is preserved. In other words, the conversion/import only repackages the raw data and does not apply the demosaicing algorithm.
Does this sound right to you? Am I missing something? If correct, the case for converting to .dng is now stronger (for me).
Thanks,
John
Thanks,
John
