I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
I do when shooting RAW in manual mode.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
photographylife.com
You'd better skip the technical explanations in that article as they seem to be a mixture of information taken from here https://dpreview.com/articles/0388507676/sources-of-noise-part-two-electronic-noise and author's own misunderstandings.I do when shooting RAW in manual mode.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
If shooting JPG, you can't.
Better to brighten photos in post where you have more control over the tone curve etc.
Digital amplification in-camera is no different from digital amplification by brightening the photo in Lightroom, except that the former decreases your dynamic range and makes it harder to retain detail in the highlights.
https://photographylife.com/iso-invariance-explained
It's not ideal, but I like it more than 'ISOlessness'. It's not ISO that's invariant, it's the visible noise that's invariant against ISO setting in-camera after pushing the 'exposure' slider in Lightroom.I do not like that term. If there were true invariance - why not glue your ISO lever, figuratively speaking, to ISO 100 or ISO 64000?
About choosing ISO below what the camera suggests - I use it when I shoot concerts. Without it, the extreme contrast could blow the highlights I wanted to keep. I was doing this even when l was shooting with lower DR cameras but I was more careful then.
I understand that. What I do not like about this term is that the highlight clipping is ISO dependent, and this remains hidden.It's not ideal, but I like it more than 'ISOlessness'. It's not ISO that's invariant, it's the visible noise that's invariant against ISO setting in-camera after pushing the 'exposure' slider in Lightroom.I do not like that term. If there were true invariance - why not glue your ISO lever, figuratively speaking, to ISO 100 or ISO 64000?
We change the ISO value, the noise stays the same - that's invariance.
I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs. I mostly ignore it.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
Exactly. Canon cameras typically have two levels of signal amplification that affects noise in shadows. For the R5 the second one is at ISO 400 if I'm remembering correctly. ISO settings higher than that just push the data to the right.I understand that. What I do not like about this term is that the highlight clipping is ISO dependent, and this remains hidden.It's not ideal, but I like it more than 'ISOlessness'. It's not ISO that's invariant, it's the visible noise that's invariant against ISO setting in-camera after pushing the 'exposure' slider in Lightroom.I do not like that term. If there were true invariance - why not glue your ISO lever, figuratively speaking, to ISO 100 or ISO 64000?
If the camera is not ISO invariant then increasing ISO reduces noise as well.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs. I mostly ignore it.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
Turning the ISO dial has no impact on shot noise, only changing the amount of light collected while the shutter is open impacts shot noise.If the camera is not ISO invariant then increasing ISO reduces noise as well.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs. I mostly ignore it.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
The ISO standard does that, but the ISO setting also controls internal camera parameters. In particular, it affects the input-referred read noise. The effect is specific to the design of the camera.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
What matters is the SNR, not shot noise alone. Shot and read noise matter. The larger the exposure, the larger the shot noise (but the higher the signal). The lower the exposure, the more read noise matters.Turning the ISO dial has no impact on shot noise, only changing the amount of light collected while the shutter is open impacts shot noise.If the camera is not ISO invariant then increasing ISO reduces noise as well.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs. I mostly ignore it.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
Dual conversion gain, controlled by ISO settings, significantly influences SNR.The ISO standard does that, but the ISO setting also controls internal camera parameters. In particular, it affects the input-referred read noise. The effect is specific to the design of the camera.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
It's not irrelevant to consider the ISO setting when trying to optimize image quality, although doing so may be overrated.
Yes it does, but I suspect that sometimes people may pay too much attention to it.Dual conversion gain, controlled by ISO settings, significantly influences SNR.The ISO standard does that, but the ISO setting also controls internal camera parameters. In particular, it affects the input-referred read noise. The effect is specific to the design of the camera.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
You raise an excellent point. There is the ISO standard, which relates to the lightness of jpgs, and there is whatever other occult, undocumented, and idiosyncratic stuff the manufacturers also do with that camera control from time to time. Still no “invariance”, though. I get it, there is empirical evidence that suggests that there is …something… they do maybe once but not at every turn of that dial, and that they don’t document. Whatever it is that they do, they don’t think I need to know about it, and neither do I.The ISO standard does that, but the ISO setting also controls internal camera parameters. In particular, it affects the input-referred read noise. The effect is specific to the design of the camera.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
Agree that it is, at least, overrated.It's not irrelevant to consider the ISO setting when trying to optimize image quality, although doing so may be overrated.
Perhaps, but what you are talking about is not part of what the relevant ISO standard specifies. Anyone who wants less noise should seek more light and forego all speculation as to occult processes.What matters is the SNR, not shot noise alone. Shot and read noise matter. The larger the exposure, the larger the shot noise (but the higher the signal). The lower the exposure, the more read noise matters.Turning the ISO dial has no impact on shot noise, only changing the amount of light collected while the shutter is open impacts shot noise.If the camera is not ISO invariant then increasing ISO reduces noise as well.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs. I mostly ignore it.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
Increasing ISO can reduce in-camera noise. On the one hand, by switching gain (dual conversion gain). On the other hand, by decreasing the noise from conversion to digital. The Canon EOS 5D is an example where increasing ISO improves noise in shadows:
https://www.photonstophotos.net/Charts/PDR_Shadow.htm#Canon EOS 5D
Indeed, way too much. None of the occult stuff will do you better than just getting more light.Yes it does, but I suspect that sometimes people may pay too much attention to it.Dual conversion gain, controlled by ISO settings, significantly influences SNR.The ISO standard does that, but the ISO setting also controls internal camera parameters. In particular, it affects the input-referred read noise. The effect is specific to the design of the camera.I don’t believe in ISO “invariance”. ISO is a function that controls the lightness of jpgs.I recently was made aware of ISO invariance (yeash, a bit behind the times I suppose). If you take advantage of this, and are using it in your workflow, I would be curious to hear about how and when how and when you use (or choose not to use it).
So in certain (pretty common) conditions you'll be getting highlights blown, and I won't be getting highlights blown under the same exposure settings but lower ISO setting.Whatever it is that they do, they don’t think I need to know about it, and neither do I
It's overrated for those who don't need it, in the technical sense, in their typical shooting conditions.Agree that it is, at least, overrated.It's not irrelevant to consider the ISO setting when trying to optimize image quality, although doing so may be overrated.
