... and you have dynamic range hysteria stew.
First you start with some basic theory about pixel pitch, add some simple math, now toss in a few tests for tonal response and call them dynamic range tests and viola - you gotcha some stew!
So lets unravel it a bit. The pixel pitch is a significant issue. But it isn't the whole story. My 2/3" Coolpix 8400 gives up only one stop of DR to my E-300/330/500. Simple pixel pitch theory math says there should be a two stop difference.
The change in pixel pitch from a 7.5Mp to a 10Mp 4/3" sensor just using simple pixel pitch math should result in around 1/3 of a stop difference. DPReview "measured" twice that. Of course, DPReview says that the Panasonic DMC-L1 has about a half stop more DR than an E-330 that uses the same sensor. That should be a big clue that DPReview isn't really measuring DR.
But there is very good reason to believe that the pixel pitch math shouldn't even be applied to the E-410/510. Panasonic says that they kept the photodiode the same size in the 10Mp L10 that presumably uses the same sensor. So it should have almost exactly the same DR as the E-330 and L1.
Then Olympus committed the sin of letting people make JPEGs with the noise reduction disabled. Oops!!
BTW, I've measured the L1 and it seems to have about 1/10 or so less DR than the E-330. Maybe Olympus is processing the signal a bit more cleanly. I notice pattern noise at high ISO in the L1, so I wouldn't be surprised.
I'll re-extend my invite to anyone in the general vicinity of Phoenix, AZ that I'd be happy to meet up and run some DR tests on one of the new cameras with the 10Mp sensor. That would give an objective comparison to the existing E-300/500/330 line.
So that's the DR hysteria stew as I see it. Lots of steam, some smoke and a rather foul smell.
I was under the impression that it was generally a 4/3 problem rather
than just E-410/510 specific.
Actually, I think you are right. The current concerns seem to revolve around those cameras and projections about the E-3.
Jay Turberville
http://www.jayandwanda.com
