Ap0ll0n
I am deciding whether to keep my (full spectrum) IR converted X-E2 with the Fuji 8mm lens or use my GFX 100S ii with the 20-35mm (and not only) for IR. So I took a test photo today in less than ideal for IR lighting, i.e. not 100% sunny on a summer day, but still probably good enough for comparison purposes. Both cameras with a Hoya 720nm filter.
The GFX 100S ii was shot handheld at 1/4sec twice and I kept the best shot. This is how I plan to shoot it in real life so I wanted the test to be pragmatic, albeit with some (unknown) variation that, if anything, doesn't do the GFX any favors. I plan to repeat when I have more time with a tripod. Somehow during PP, Photoshop or Nik software removes exif so here it is:
Both lenses at f/4, Fuji X at 1/240sec and ISO 200, Fuji GFX at 1/4sec and ISO 800.
I already know the GFX is (imho a lot) sharper but here I cared more about noise. Sure enough, you don't expect the GFX to be more than 2 stops better but more on that towards the end.
I applied my typical PP to make both images at least presentable: select white balance (again, as already done in camera) against the grass -> swap channels in Photoshop -> Nik 7 Silver Effex (high contrast and structure in this case).
I do need to highlight that the Fuji X photo at that stage stood out by a lot more. Part of that may be attributable to different lighting (again, if anything not favoring the GFX but need to repeat). For the GFX one I had to further select the trees and building and increase their exposure (and shadows). And get rid of a bit of hotspot in the middle (can you tell?!).
As a final step, again keeping in mind my use case, I applied my favorite (for my monitor) 2.1:1 crop ratio to both. Now, I know this is not doing the Fuji X any favors, due to lower MP, but again I almost don't care as I am only interested in finding out which one can provide the better output.
So here are the results. The noise is, I believe, noticeably higher on the Fuji X, despite that being shot at a two stops lower ISO! Of course, this is due to both the larger sensor but also due to the last magnification step I applied - I'm sure Erik will chime in here to quantify how much each factor contributes
First of a few tests on a genre of photography I really enjoy.
Fuji GFX + 20-35
Fuji X-E2 + 8mm
Apollon
Fuji GFX + 20-35
Fuji X-E2 + 8mm
Apollon
