Infrared with one filter, different results
MacM545
Leading Member
Eaton Rapids, MI, US
The images in this post were taken using a single filter on a Full Spectrum camera. I bought a Variable Neutral Density filter for my regular camera that is not converted in any way. I decided to see how it would behave on the camera that can see Infrared light in addition to Visual light. The first image was made at the maximum setting of the filter, or the setting at which the filter is the darkest; however, on the full spectrum camera, the exposure doesn’t change much when adjusting the darkness. Each image, except for the first and last, were taken at intermediate steps of darkness. The last image was made when the filter was at it’s brightest setting. Based on this finding, the range of wavelengths being passed by the filter appear to be approximately 680nm and up (last image), to approximately 800nm (first image); even though it’s hard to tell, the first image does have color data.
Something interesting to note about this regarding Infrared photography is that this is in some way similar to an adjustable Infrared filter, except that unlike a usual Infrared filter, the range of light spectrum that passes through this is different if one were to plot it on a spectral graph; It seems like at each setting, it passes either Green light, or all light within the visual light spectrum, but to different amount, while passing Infrared light also.
