Hello
I have a couple of wide gamut monitors which I have calibrated with a spyder3 and the profiles are definitely getting loaded when I enter the operating system.
I was under the impression that with the calibrated monitor profile loaded, everything running in windows would be passed through this profile.
Now what confuses me is:
When I use FastStone viewer or Irfanview and turn on ICM mode, then load in a jpeg that has a sRGB profile, the colours are still over saturated. I thought that the ICM in faststone / Irfanview was doing the colourspace conversion, and the windows monitor profile was then modifying the output?
The FastPictureViewer which has both ICM + "Monitor Output profile loader" built in, displays the image as it should look.
Photoshop displays the image correctly
Firefox 3 with ICM turned on displays the image correctly
So does this mean that image viewing applications somehow bypass the operating system's loaded monitor output colour profiles?
Thanks for any info on this that you can provide.
Regards
Cas
Regards
Cas
