MJ_Photo38
Hi, so a couple of days ago, I made a thread about debating if I should sell my X-T2 to get an X-Pro 2, as my X-T2 has been sitting on a shelf for the better part of the last few months (mostly because I have both more fun smaller and larger better performing cameras. If you want to have more details : go there )
Long story short, I put my X-T2 back in its box, and bought an X-Pro2, which arrived this morning. The listing made no comment on the potential defects, only said it was in "extremely good shape", and since it was used by someone shooting mostly film, and the very low shutter count (under 15k) + the very good reviews of that seller, I was enclined to trust the process and not be too suspicious.
Problem is, the camera is NOT is good shape at all, and I could not make it out in the low resoution images on the listing itself, as you can see in some photos I took this morning :
the door is supposed to be flush with the rest of the body
the bar holding the door is supposed to be straight.
As you can see in the pictures above :
- the OVF/EVF plastic housing has taken a pretty nasty hit
- same thing for the bottom plate, which is bent and slightly fractured around the imapact point (some black marker was applied to hide the grey color that was under the paint)
- the SD card door does not sit flush, and it too far away from the body for the spring to actually do something, probably because the bar holding it is bent out of position.
I have 3 days to make a return, in which case I will be fully refunded, however the seller indicated me that if I was willing to keep it, he would make me a 50€ transfer as compensation for the damages (this seems low).
So here's my thing : I am personally not bothered by cosmetically damaged cameras. I own my fair share of them (my X-T1 is damaged, repaired, then damaged again and barely ressembles an X-T1 now). I also like to fix stuff myself if I can.
However I don't know if things can even be fixed. Sure, I can replace the bottom plate with a new one (If I can find one),but would it even be wishable? Wouldn't this create problems and would require a full swap of the components that might have been damaged by the fall?
I also have no idea how compromised the weather sealing would be. I'm not shooting in the rain often, but that can (and will) happen at some point. If this has no impact, that's one less thing to worry about, but I somehow doubt it.
Mu gut feeling says, go ahead and return it, and maybe search for another one (or take this as a sign I should keep my X-T2 lol), but maybe I'm being dramatic.
I tested the camera this morning and it's 100% functional otherwise (every shutter speed, ever OVF function, every button / dial etc)
(G.A.S. and collectionnite will get my skin one day)
