This image look very strange and not like a DP2m at all. It's too blue, blurry and seems to have noise reduction applied.
Maybe you can try to export the file as 16Bit TIFF without noise reduction in SPP and check the problematic area again?
Thank you for the reply maceoQ,
did you see the whole image under the link i provided ?
It was the 4th image I took after I got the camera brand new in the morning. So as the rain stoped I went out to play around with it.
It handles a little different than the DP1 or my SDs so may be I have to get used to it and learn how to handle the files from it.
Here are the EXIF datas :
---- File ----
FileName : SDIM0004.jpg
---- EXIF ----
Make : SIGMA
Model : SIGMA DP2 Merrill
Orientation : Horizontal (normal)
XResolution : 300
YResolution : 300
ResolutionUnit : inches
Software : SIGMA Photo Pro 5.5.3.0001
ModifyDate : 2015:02:21 21:54:15
YCbCrPositioning : Co-sited
ExposureTime : 1/100
FNumber : 4.0
ExposureProgram : Program AE
ISO : 100
ExifVersion : 0220
DateTimeOriginal : 2015:02:21 16:58:49
CreateDate : 2015:02:21 21:54:15
ComponentsConfiguration : Y, Cb, Cr, -
ExposureCompensation : -0.7
MaxApertureValue : 2.0
MeteringMode : Unknown
Flash : No Flash
FocalLength : 30.0 mm
FlashpixVersion : 0100
ColorSpace : Uncalibrated
ExifImageWidth : 8400
ExifImageHeight : 5600
SensingMethod : One-chip color area
FileSource : Digital Camera
CustomRendered : Custom
ExposureMode : Auto bracket
WhiteBalance : Auto
FocalLengthIn35mmFormat : 45 mm
SceneCaptureType : Standard
ImageUniqueID : 303034313731323449B9E85431444539
---- MakerNotes ----
SerialNumber : 904xxxxxx
DriveMode : SINGLE
ResolutionMode : HI
AFMode : AF-S
FocusSetting : AF
WhiteBalance : Auto
ExposureMode : Program AE
MeteringMode : Unknown (S)
LensFocalRange : 30
ColorSpace : ROMM RGB
ExposureCompensation : +0,0
Contrast : +1,0
Shadow : -1,0
Highlight : -0,3
Saturation : +0,5
Sharpness : +0,0
X3FillLight : +0,2
ColorAdjustment : 11C+8M
AdjustmentMode : Custom Setting Mode
Quality : 12
Firmware : 1.05.1.7093
AutoBracket : 1 of 3
ChrominanceNoiseReduction : +1,000
LuminanceNoiseReduction : +0,750
ColorMode : FOV Classic Blue
Thanks for your suggestion. 16Bit Tiff might be the way to go.
Also I´ll not use the FOV classic blue mode in the future, because it is not what it promisses. It was just a trial to see what it does. Now, anyhow in SPP the letters are white, but I think PSE is causing the coloration. I have to take a closer look at that too.
Thank you once more,
Rudi.
