I want to do all sorts of dynamic things with my product, food and drink photography.
There is the QT series of Godox, which is positioned as flashes for quick shooting, but it is very expensive, in fact it costs the same as their battery-powered AD series.
So I thought, maybe there is no need for it? Maybe some flashes from their more budget series will be able to handle, say, 7-10-12 frames in a row at 1/8-1/16, maybe 1/4 power? After all, even my Canon Speedlight 430 EXII can took couple frames in a row. But I don’t see any detailed tests anywhere, and frankly, I’m confused about their studio flashes. They have produced so many series ! QT, QS, MS, DP, SK, SG, DS. Which brings up my second question: How to figure all this out ?
Let's say QT is a high-speed top series, then QS is a top series with a high-quality case from QT, but not high-speed, MS looks quite compact, I guessed that this is a compact series.
But the rest look the same. Except that the DP series looks more powerful. Starts at 400 and goes up to 1000. And here is another question - does this power make a bigger "buffer"? Maybe this DP1000 will be as fast as QT-400? Because where for QT400 it is 1/2 for DP1000 it is only 1/8+2/3. Or does it not work like that?
So yeah, I'm confused. What should I look for if I want to squeeze more juice, more in terms of power/speed/number of charges in a series, but I don't want to buy a flash of the most expensive series ?
Thank you
Thank you
