mister sunshine
Well-known member
- Messages
- 193
- Reaction score
- 28
Hello,
I am trying to learn of a mathematical way to compare differing photographic systems in a way that considers the field of view or magnification on a per pixel basis.
The reason I am asking about this is that I am hoping to be able to compare digiscope photographic equipment with traditional DSLR set ups.
I am currently making photographs of birds with a Canon 5DSR and a Canon EF 600mm f/4L IS II and the 1.4x Teleconverter, and I have recently purchased a Kowa 883 spotting scope with a 25x-60x zoom eyepiece.
I estimate that the 600mm with 1.4x optics on a full frame system equates to approximately 16x magnification.
I also own a Canon 7DmkII camera body. This camera is my first "crop sensor" camera as I have previously only owned 35mm film cameras and Full Frame digital cameras. Owning the 5DSR and 7DmkII at the same time has let me consider the implications of the term "crop sensor". These two cameras have almost identically sized pixels and so, when using the same size lens, the photographs made by the 7DmkII do indeed seem cropped compared to the photos made by the 5DSR.
This has led me understand that the often mentioned characteristic "1.6x" and the idea that ASP-_ sensors have an increased telephoto effect when compared to full frame cameras is only applicable if the ASP-_ sensor has a higher density of smaller pixels on the camera's sensor.
This realization has caused me to have an interest in comparing my DSLR capabilities with the capabilities made available with the possible acquisition of digiscoping accessories for my Kowa 883 scope.
The micro four thirds Panasonic Lumix GH4 is frequently recommended as a good match to the Kowa spotting scope and there are accessorizes that make the use of such a camera easy. I'd like to start by making some comparisons based on that system.
I have been able to compare another photographer's pictures made with the Kowa 883, 20x-60x eyepiece set at 60x, a Panasonic Lumix GH4 with a 20mm f1.7 lens with a photo I made of the same subject from the same viewing location using my DSLR. This gave me some idea of the difference in effective "magnification".
Now I would like to learn how to mathematically understand the differences.
It occurs to me that learning the effective field of view that is represented by each pixel may be the most specific way to compare different digital imaging systems.
I can start with some basic ideas:
Canon 5DSR sensor 36mm x 24mm sensor = 864mm²
Canon 5DSR; 8688 pixels x 5792 pixels = 50,320,896 pixels
Canon 5DSR sensor's pixel size = 0.00414mm²
Panasonic GH4 sensor 17.3mm x 13mm sensor = 224.9mm²
Panasonic GH4: 4608 pixels x 3456 pixels = 15,925,248 pixels
Panasonic GH4 sensor's pixel size = 0.00375mm²
I am writing to ask for help and guidance in furthering an understanding.
What other information do I need to gather and how do I use it to arrive at an understanding?
Thank you.
Thank you.
