I have been long searching to no avail, so would be grateful for any practical experience on a particular issue with high resolution mode and noise reduction in long exposures.
By way of background, I use a Lumix G9 a lot for long-exposure photos of gloomy building interiors, always using a tripod. I often want to maximize resolution as I am recording historic fabric before and during conservation works, but when using high-res mode I am limited to a 1 sec longest shutter (the limit of the electronic shutter) and also by the fact that there is no dark frame subtraction (unlike in the normal mode). As a result, hot pixels are not eliminated and appear quite large (multi-pixel) due to the pixel shifting: they are a real pain to remove in post, especially as I want to retain detail.
So I am exploring alternative cameras. Obviously, I could use a decent resolution full-frame camera without the need for pixel shifting, but that is where I came from: in my fifties I got tired of lugging my Nikon D810 and several large lenses (14-24mm etc.) up scaffolding and ladders etc., and have otherwise enjoyed the compactness of M43, esp. in terms of lens size. So I am wondering about M43 alternatives.
Sadly, the GH6 didn't adopt the S5's advances in long-exposure high-res mode, so has the same limitations as the G9 in this regard: the S5 high-res mode was improved to allow longer exposures (8 sec max, which would pretty much be OK for me) and dark frame subtraction noise reduction. Of course, any future G9 mk2 may be similar to the S5 in this regard, but we have no certainty about this or indeed that there will even be a G9 mk2.
Finally, then, the question: how does the OM-1 implement high-resolution mode in terms of long exposures and noise reduction? I have searched, read the OM-1 manual and have so far found no answer. Is the OM-1 electronic shutter of 60 secs the limit on the exposure of a tripod-mode high-resolution photo? Can long exposure noise reduction (dark frame subtraction) be used in high-resolution mode? And, finally, if both these are the case, is this as effective at removing hot pixels in high-resolution mode as it is in normal mode?
Sorry for such a long post, but, hopefully, this makes things clear.
Many thanks - in anticipation - for anyone using an OM-1 in this way.
Roland
Roland
