DigitalCrazy
Leading Member
If money is not an object and you could get the 1D over the 10D what would be the reasons?
Mr & Mrs. Digital Crazy
--If money is not an object and you could get the 1D over the 10D
--1. AF much much faster
2. 100% viewfinder
3. Controls more ergonomical
4. Weather sealing
5. 1/500th flash sync !!!
6. Ambient & flash exposure scales in viewfinder
7. 8fps
8. Firewire interface
9. 45 focus points, 7 of them being CROSS sensors
10. True spot meter
11. Better build quality
12. 1.3X mag factor
13. 1/16,000 max shutter speed
14. Extremely short viewfinder blackout during exposure
Sorry, that's all I can think of off the top of my head.
--Nuff said ?
2. 100% viewfinder
4. Weather sealing
7. 8fps
10. True spot meter
12. 1.3X mag factor
--The only thing you need Firewire for is to connect your camera and
program custom functions. However, if you're considering $3500 for
a camera BODY then you owe it to yourself to spend another $50 and
get a Firewire card for your PC.
2. 100% viewfinder
4. Weather sealing
7. 8fps
10. True spot meter
12. 1.3X mag factor
2. 100% viewfinder
4. Weather sealing
7. 8fps
10. True spot meter
12. 1.3X mag factor
Come on Paul, you should know better than that. They are both cameras, and each has its strengths and weaknesses.Nuff said ?
