Jack Pangolin
Member
- Messages
- 13
- Reaction score
- 14
Hi everyone !
I can't seem to find fully enlightening information about how harmful can the effects of sun framing be on modern mirrorless camera sensors.
I have used DSLR for years and recently moved to MLC 8 months ago (R5)
I'm about to word what is my understanding of that question and then share a personal project I'm willing to undertake.
I do not pretend to own the truth on this but would like to point out some lack I regularly find in topic-related articles.
Many thanks in advance for your attention and answers !
As a starting place, some basic reminder: Unlike DSLR cameras, an MLC's sensor is permanently exposed to the lens-driven light. As a result the sensor may be exposed during extended periods of time to intense direct sunlight by merely framing the sun through the EVF.
To this extent, the shots themselves are now of minor matter, but long exposure ones.
In an attempt to explore the question,
1/ I suggest that a sensor may start burning whenever it reaches a global temperature during a certain amount of time.
2/ I suggest that a sensor may start burning "locally" whenever a given area within its surface reaches a certain temperature / energy.
I'll enter more closely those two leads, provided the following use case: the sun is being framed through the EVF of an ML camera, the camera is being hand-held (no tripod used) and short exposure shots are being taken.
1/ The global temperature of the sensor mainly depends on the lens-driven light, which is a function of its full aperture, the amount of time spent, and the focal length which will grow or shrink the appearing sun disk and therefore increase or decrease the overall sunlight hitting the sensor.
2/ The "local" energy issue depends on the lens's full aperture as well, but not on the focal length any longer. Not at first glance at least. What matters here is the sun's local intensity, its light concentration, not the total captured light. Indeed, the sun is as much intense and concentrated should it be hitting a 1mm² or a 20mm² area of the sensor.
What particularly matters here is the amount of time the sun image will be hitting the same area of the sensor. To this extent, the focal length does matter afterall, as it will make the sun "slide" by the photographer's moves more or less on the same areas depending on the size of its appearing disk.
This very issue often seems overlooked by many topic-related articles which mainly focus on the global temperature issue.
Now,
LensRentals had released an interesting article about camera gear destroyed during a solar eclipse.
However this article does not approach the technical aspects of the damaging process.
https://www.lensrentals.com/blog/2017/09/rental-camera-gear-destroyed-by-the-solar-eclipse-of-2017/
Interestingly, irises can be harmed, whatever focal length used. But what strikes me most are the damages seen on shutters and sensors, which are razor sharp, concentrated like imperial laser shots. This makes me suggest that it's the straight sun image hitting the shutter or the sensor that harmed the area, not the overall captured light.
The shutter or the sensor just cannot seem to sustain the local sun intensity passed a given amount of time.
In other words, the "local" energy issue seems to be a concerning matter whatever focal length used.
Therefore, even a wide angle lens, if headed to the sun a sufficient amount of time may damage the sensor.
Does this understanding of the issue sound relevant to you ?
If so, what time a sensor can sustain the direct sunlight hitting approximatively the same area before starting to burn locally ? Is that a matter of seconds ?
I doubt anyone can answer to this, but camera makers' R&D department personal. Yet feel free to share your thoughts !
Now, I'll share a photo work I'm about to undertake under sun-related stressful conditions.
I'm willing to take pictures of a person in plain sunlight (not during sunset), with the sun being framed in the back.
The exposure settings will be about as following: F/14, 1/640th, iso 100, but this is of minor matter regarding the raised issue.
I'll work in manual exposure, and maybe in manual focus, in order to minimize the time spent facing the sun for every shot I'll take. Only the subject's moves and the picture framing will make me spend some time facing the sun.
Also, I'm decided to use the depth of field preview button while framing in order to split the sun intensity between the iris and the sensor.
My last questions are then:
Has any one of you friends ever tried to frame the sun on the back of photographs on a hand-held MLC for extended periods of time ? (whatever lens used)
Has any of you ever tried to frame the sun on an MLC set on a tripod using a wide angle lens ? (say 28mm or less) For instance for landscape shots.
How did all this eventually turn out ?
I hope I have made my approach sound clear enough for you to understand (as english is not my native language) and thank you all for your kind help and enlightenment.
Now,
