Kent Ekasak
Leading Member
- Messages
- 819
- Reaction score
- 990
S1RII:
It's slightly thicker than the S5, but the grip is more comfortable.
The tilting screen is a game changer for me in many use cases, such as sports, wildlife photography with long telephoto lenses, and travel.
The photo/video/S&Q switch is another game changer, allowing 3x customizable options from previous models.
A reviewer mentioned that the on/off switch is hard to click, and I agree it's true.
Finally, I found the worthy upgrade from S5 in every aspect.
BF:
Black version looks cool, but if you're considering buying the BF, I'd recommend the silver version, that's what the BF is made for. However, that means you'll need to buy more silver lenses to match, making the total package more expensive.
The grip is okay, not as bad as it looks, but it requires more careful handling. BF looks like an expensive craft than a workhouse.
As a former FP owner, I find the BF menu has a learning curve. I personally prefer the FP menu.
AF is better than the FP for sure, but don't expect it to reach Lumix's level.
When you switch it off, the tiny screen displays the battery percentage. It's pretty cool.
You can't use any Lumix battery with the BF. That's bad, because FP uses the same battery as G90.
IMHO, the main reason to buy the BF is for its artistic external design and silver finish. Otherwise, I'd go for the S9 instead. It's $500 cheaper too.
I think existing Leica L-mount owners are likely to buy BF than Lumix's owners.
BF:
