I have had the camera for two weeks, and I am going to keep it. That said I have noticed some "bug-a-boos" that I thought I would helps some people out.
- The physical controls are nice, but can be an issue.
- Using them slows me down too much so I move all the dial functions to the front and rear dials and use the front button to cycle through.
- The zoom lever is too easy to move so I locked it down and press the unlock button to change zoom.
- The on off switch doesn't move enough. What I mean is I can't tell from feel if the camera is on or off, and I have heard of people turning it on by just adding it or removing it from the bag.
- The joystick sometimes needs a second press in the various directions. I have been trained to push twice to make sure it is moving.
- Focusing
- All of the focusing modes work, when they want to, but they are not 100% and that slows me down.
- If I am going slow, and have one or two subjects the Face/Eye detection works well. If I leave the camera on this type of autofocus, it becomes less reliable.
- I like to focus and recompose, and I don't do that with the joystick (see above). I use AF-C, half press and recompose. Works well for me.
- Manual focusing is pretty good, especially from f8 and up. I am finding the manual focus scale reliable and consistent.
- I like speed so I set the focusing to release not focus. I am getting my shots in focus, so this is working for me.
- Lowlight focusing, surprsingly good, but there are limits. There are times when I can't make out whats on screen because everything is so dark, but the focus is usually spot on. Actually not an issue...
- Sound
- I just turned it off. I like the number 3 sound, but half the time it doesn't register/play, so I turned it off.
- More reliable focusing. It isn't bad, it just isn't what I am used to coming from Sony.
- When the ratio dial is set to C, they should let us select which ratios we want to use. I would limit my self to 17:6, 1:1 and 4:3, now I have to scroll through a few to get to them.
- Ability to zoom in video at the same points as photos.
- Would love for the feature that is being adjusted via the C button to change to a different color while it is selected. Looking for the little wheel slows me up.
- Cost - Seen as a gateway to MF with the same sensor as a Hasselblad, and with a leaf shutter, this camera is a value leader.
- f4 - Shoot outside, add a flash, up the iso, recover in post, or get closer.
- IBIS - Won't stop your moving subject from being blurry, so up the shutter speed. Several have mentioned 1/125 for consistent sharpness hand held I agree. If I need to go lower, I will add a flash, and that seems to maintain the sharpness.
- Even though this camera is slower than what I am used to, it is fast enough. I just need to practice to get the speed and consistency up.
- And the files are gorgeous. Even the grain/noise at high iso is small enough that I consider it a feature. Can't wait until DxO finishes its update so I can test the files with DxO.
