highdesertmesa
One complaint about the GFX100RF ratio dial is you may have a favorite ratio you like to use in addition to 4:3, but they're separated by several steps on the dial, which can be inconvenient. Tip: set the ratio dial to "C", and then use an assigned function wheel to set the image ratio to your favorite one. Once set, you can reprogram your function wheel to whatever setting it was being used for previously. Since 4:3 and "C" are next to each other on the dial, you can now switch back and forth between 4:3 and your favorite ratio with a single click. I have "C" set to X-Pan.
