Getting rid of tiny white dots?
Flycaster
Boynton Beach, FL, US
I am using Photoshop Elements 2025, and trialing Photolab 9 on my PC. In the edited photo below, see the many little white dots. How should I eliminate or not even have them? I know I can eliminate them by using PSE's spot healing brush, but that is just too tedious, and Filters>noise>Despeckle doesn't work. Is the appearance of these dots related to over-sharpening, or do they come with the territory? Thanks.
Don't overprocess photos.
They're objects that exist in the original scene, but transformed by your processing, Everything in the image looks like a painting when viewed at full magnification,
This was not a good photo to begin with, and i know that I over-processed...which is something I know I have to control.
But, even if I didn't over-process, all those dots probably still would have appeared. Here's a jpg of the raw. RAW sent to PSE's ARC (no intentional editing) and then to PSE (no intentional editing,) and then saved. Interested in seeing what you can do (not using blemish tool) to remove spots:
Yeah, I know it wasn't a great capture to begin with, just wanted to send an example.
Because they exist in the scene.
I don't want to remove them. They were there. Notice how there are absolutely none in the out-of-focus background, so they were not introduced by the sensor.
Your DOF was very shallow, so only a few parts of the scene are in good focus. You might have to live with that, depending on how large the final result needs to be.
I ran that JPEG through Topaz Photo AI with only some noise reduction (which automatically applies a bit of sharpness as well):
That's as far as I would go. If you want the spots removed without doing any manual work, you could try an AI tool as suggested earlier.
Those are things that were really there but you exaggerated them by overprocessing the image. What settings did you use?
Tom
I don't know if they have a free trial, but the PS plugin SRDx from Lasersoft Imaging sometimes does a surprising job depending on the photo.
I did look at some of the free AI's, but they all seemed to use a "blemish tool,' which means doing the removal manually. Could you suggest an AI that one would have to do is request that the white dots be removed?
I'm talking about AIs that accept text prompts as instructions to alter images, like this: 'Remove the white spots in this attached photo.'
I cannot. The ones I know about will only produce tiny images of about 1-2 megapixels, which I'm sure would be useless for your purposes. Others here might have suggestions, though.
Crappy screenshots, but here are
original photo, marked photo, and "optimized" photo using SRDx:
Don't recall the ued settings, but I obviously did over process a poor image.
I have found that too much micro contrast causes that effect.
I know that I did use "some" micro contrast, but can't recall how much. However, I just dl'd SDRx for a free trial. Really don't know how to efficiently use it, but giving it a rough try, it seems to do a reasonable job in getting rid of most of the white spots. Only thing is that the masking tools seem to be missing in the trial? Now, I have to decide if $49 is worth it? Then again, knowing I tend to over process, it might be good to have?
I just tried the SRDx trial and it seems to work real well. My only question is that the trial seems to be missing the masking tools. Maybe they will be there with the paid for version?
Yes, the masking tools work for me in Windows 10 and 11.
If I can control my tendency to over process..fine; but, if not, it looks as though SRDx is going to fit the bill. Just been doing some initial editing with it, and it certainly does a good job. Here's a before and after. BTW, the free trial winds up with a huge water mark, but I still think you should be able to see a remarkable difference.
Before
After
enjoy!
Despeckle is not strong enough to handle these relatively large white spots. Instead, use the Dust and Scratches filter. A radius of around 8 and threshold of around 70 nicely cleans up the white spots without having much of an effect on the rest of the fine detail. Here's your unedited version cleaned up with those settings and nothing else changed:
Which program was used?
Photoshop, but I'm pretty certain that PSE also has this filter.
