kwaller
Leading Member
Just a quick question as was just talking to someone on the AmateurPhotographer forum as he was asking about IR modded cameras ( you know the one, the UK mag that gave the SD14 such a bad review) i tried to tell him that the SD14 was ideal for IR photography as you just have to remove the dust protector and use the correct filter and away you go
he came back with the following
quote no 1
The "dust cover" is probably the IR blocking filter! Also it has optical thickness, unless you replace it with a plain glass slip the focal plane will be moved forward by about 1/3 of the thickness of the missing "cover" and you may have difficulty reaching infinity focus with some lenses.
Having said that, for all I know (nothing), it may be easier to remove the IR blocking filter from a Sigma SD14 than from most other makes and models. All the same I'd be surprised if you weren't trashing your warranty by doing so.
told him that removing the dust protector would in noway "trash the warranty" and that if he looked at the SD14 site he would see that it is designed to come out tried to get him to visit the SD14 web site and here to get the correct info but he came back with the following quote
If that's the case then clearly there is no issue with warranty. But unless the dust protector is infinitely thin or is made from a material with a refractive index of 1.0 (and I never heard of one) then removing it will change the optical distance between the mount flange and the focal plane. You might not notice this if your lenses have sufficient travel past "infinity" to be able to compensate, but if you focus using the distance scale (as is almost inevitable when using a "black" IR filter) you may still fall foul of this.
Thanks for enlightening me.
and then this
No, I haven't seen a SD14. And the web site requires Flash, which I will not have on my computer as I believe the Adobe binary version creates serious security loopholes. There is an open source version under development but it doesn't work well enough to be useful yet.
If there is a piece of glass or other transparent material in the optical path, it refracts (shortens the wavelength of) the light passing through it The wavelength of the light is restored when it leaves the material, as is its direction if the material is flat - simple lenses work by having surfaces which are not parallel to each other! Light passing at right angles through a flat plate of material of thickness "X" effectively travels a distance of "X" times the refractive index. The refractive index for most optical glass and plastic is somewhere close to 1.5 i.e. the optical thickness of the plate is about 1.5 times its thickness.
Put a 1mm thick plate between the lens and the sensor and you need to move the lens forward about 0.5mm to compensate. Conversely, if there should be one there and you remove it, you need to move the lens back about 0.5mm; the only way you can do that it to focus "past infinity". Not all lenses will let you do that. That is why the modified Canon and Fuji cameras have a clear (transparent to IR) replacement "front filter" of the same optical thickness.
This is a straightforward piece of optics, not related to the Sigma or any other camera.
so is he correct that when shooting the sd14 you wont be able to focus correctly unless the lens lets you focus past infinity?
ap forum here
http://www.amateurphotographer.co.uk/forums/showflat.php/Cat/0/Number/577174/an/0/page/0#577174
and you might also be interested in this one as well
http://www.amateurphotographer.co.uk/forums/showflat.php/Cat/0/Number/555488/an/0/page/0#555488
thanks
keith
quote no 1
and then this
ap forum here
thanks
keith
