The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
Yes, but you don't do this through the "Subject Detection" system, it is a completely different C-AF option - you have to have "Subject Detection" in the "Off" setting and then choose "C-AF + Tr".The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
Tracking apparently has been improved (I don't use it regularly), but it's still a bit awkward to use, IMO. It should be just another option in "Subject Detection" - call it "Target" or whatever.
Yep, sounds like a better approach.With Sony it's integrated. Subject tracking only works if tracking is on. It tracks whatever you lock AF on. Lock a bus and it tracks that. Lock a leg and it will work its way to an eye if it can. Lock the number on a T-shirt and it gets confused.Yes, but you don't do this through the "Subject Detection" system, it is a completely different C-AF option - you have to have "Subject Detection" in the "Off" setting and then choose "C-AF + Tr".The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
It does work within a limited set of parameters in my experience. e.g., The little white box can follow your dog/kid across a big field with no clutter in the frame, from edge to edge.Yes, but you don't do this through the "Subject Detection" system, it is a completely different C-AF option - you have to have "Subject Detection" in the "Off" setting and then choose "C-AF + Tr".The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
CAF+Tr kind of works if you pan or the target moves slowly. Not very "sticky" I find.Yes, but you don't do this through the "Subject Detection" system, it is a completely different C-AF option - you have to have "Subject Detection" in the "Off" setting and then choose "C-AF + Tr".The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
Yep. I used it extensively on my E-M1 and E-M1 Mark III's - for hundreds of thousands of photos over the years. It can work in the right situation, but you typically have to make sure you've got enough DoF to hide focusing inaccuracies. I had to use it while documenting hardcourt bike polo because Face Detect and C-AF didn't really work with Helmets/Face Cages. The OM-1 Mark II fixed that problem, and I never looked back!CAF+Tr kind of works if you pan or the target moves slowly. Not very "sticky" I find.Yes, but you don't do this through the "Subject Detection" system, it is a completely different C-AF option - you have to have "Subject Detection" in the "Off" setting and then choose "C-AF + Tr".The headline says it all: The OM-3 has several subject tracking AF-C modes, such as face and animal recognition. But is it also possible to set the focus point on an arbitrary object or point on the display and have the AF-C track it?
I believe it's only birds of prey (and other predators) that use tracking for food! :-DWhen I'm doing food photography, I scrap "tracking" and either use All Area or Single Area if it's having trouble picking up the particular thing I'm focusing on.
