I have noticed a lot more corrupted files as DNG ones than CR2 even though the CR2 are larger. I am going to guess here that the reason for this is that every time we rewrite a DNG file with modifications...it overwrites the existing DNG file and resaves it to disc.
If you look inside a DNG file created by Adobe's DNG Converter, the XMP is near the start, with plenty of free space after it. I believe Adobe's software doesn't overwrite the whole file, but just a block or two near the start, when it writes the XMP back.
I tend to agree with the notion that multiple writes to a DNG will increase the odds of file corruption.
And while I agree that side-car files are the best solution in terms of non-destructive editing, I'm one of those individuals who loathes all that clutter (and having to remember to keep all the sidecars in the same folder as the original).
So I retain my original RAW files, but create DNG versions which house all my edits.
Does anyone here use Irfanview? I use both Mac and PC, and move files between both OS with an external drive. On the Windows side, Irfanview is a great, low-overhead tool for viewing the embedded jpg in RAW files. I use Photo Mechanic and/or LR for most of my viewing, but sometimes it's easiest just to right-click an image file in Windows Exporer and open it with Irfanview. Irfanview can also handle DNG.
Caveat:
Irfanview has no problem displaying the contents of a DNG when it is initially created from the RAW file. But if you subsequently edit the DNG (ie, in ACR or LR adjust levels, saturation, sharpening, etc.) and then update the DNG with the new edits, Irfanview will choke everytime if you try to open the updated DNG file.
This would seem to indicate that something is not quite right with DNG and the way it retains image edits.
Tom (Marshall) Heim
http://www.pbase.com/t_heim
