I'm a new D60 owner, just upgraded from a G2. I've been shooting a lot and an concerned about the sharpness in my final images. I shoot RAW and use NORMAL conversion with Breezebrowser ("as shot") in all the other fields. I converted as clean as possible. No sharpening was applied. I shot the tree at 28.0-135.0mm IS @ 60.0mm Subject dist: 655m, 1/250 sec, f/8.0, ISO 100.
The other shot is 28.0-135.0mm @ 50.0mm, Subject dist: 5.00m
1/250 sec, f/9.5, Mode: Program, Metering: Partial, ISO: 100
Both images are from the CENTER of the image.
I'm sure could sharpen them up (and maybe I'm supposed to), but as a raw does this look correct?? I'm using autofocus in bright light. Below are two different images. Please suggest! If this is normal, I will start breathing again... I worried I got a $3000 brick...
Thanks,
joe
Thanks,
joe
