Hi All,
I have an on going underexposure problem in program mode with the on board flash as well as the SB80dx. I found this info (below) while searching for this problem. If I follow what it says will the camera not keep the shutter open until it thinks the image is properly exposed.....maybe less than 1/60...Maybe blur?? Can't try on the Camera, I'm at work. Any input would be appreciated. D100 24-85afsG db80dx
Thanks in advance....Bruno
"Any photographers familiar with the Nikon flash system should know that most Nikon SLRs require you to enable "slow-sync" if the ambient light is not sufficient to expose the background. Otherwise, your shutter speed will be locked at the lowest speed (1/60s) in P mode. Check the program line in your camera manual.
With the DX speedlight set to "D-TTL Matrix" (new 3D matrix balanced fill-flash) it amplifies the problem as the camera will try to balance exposure of your subject with that for the background.
Try and test again with the followings before trying to make another review...lol:
1) Turn on "slow-sync"
2) Set your speedlight to "standard D-TTL" (with matrix-balanced icon off), or
3) Set your speedlight to automatic "AA" mode."
