I am currently using an LG 24gq40w, the limitations of which seem to be causing me some problems for editing. As such, I am looking to replace it with a monitor which will be better for photo editing. This could be anything from an ASUS ProArt to something higher end.
Now essentially any monitor with reasonable specifications for photo work is hardware calibrated. This seems to be universally regarded as superior to calibrating with a software profile. That's great.
What has me extremely confused is the interaction between the software profiles and hardware calibration. Right now, I am using an ICC profile created with DisplayCal using my Calibrite colorimeter on my LG monitor.
What exactly am I supposed to do when I plug in a new, hardware calibrated monitor? Do I no longer worry about the profile and just leave it as it is? If so, why does it not mess up what I see on the monitor?
Or, do I instead activate a different profile? If so, which one?
Some of the hardware calibrated monitors seem to have software which is used to create an ICC profile on the computer designed for that monitor. Some have specific drivers you are supposed to install which may somehow get things working correctly. Some have instructions about setting up profiles in Windows. Yet others do not. You just plug them in and they are a monitor and that's that.
So how does this all work? How do I make sure that when I go ahead and use a decent hardware calibrated monitor that I actually get the correct colors/etc. that I am supposed to be getting with it?
