Thom Hogan
This forum gets a lot of configuration questions for new Macs. Usually that's specific to CPU/RAM/SSD choices. I'd like to point out something else everyone buying a new Mac needs to take into account: overall configuration and how the bandwidth gets distributed. Let me start with a graphic, then explain:
This is a quick example of something I'm configuring for someone. The critical aspect here is to make sure that the overall configuration works. You only have so many ports, and they can only handle so much bandwidth, so you need to consider what connects to what and why. Here I use colors to show how they connect. (Technically, the keyboard and mouse are usually connected via Bluetooth, but I show them as USB because they need charging sometimes [it's also possible that they charge from the display, depending upon what it is and how it's connected]).
The current Mac Mini has either two or four Thunderbolt ports (blue) and two USB ports (green). Note that I've defined five Thunderbolt devices and five USB ones, so they can't all directly connect to the Mini. It's possible to hook the second display to the Mini via HDMI, and that's one of the reasons why I put together this diagram, because I'm trying to balance bandwidth/connection loads. Both the OWC MiniSTX and Satechi are hubs, which can take their bandwidth and either pass it through or split it out. The Orico is just a "bunch of disks in a box"; it can pass through, but I'd be worried that all the drives in it could eat pass-through bandwidth.
Is this the best possible configuration for the user? I don't know yet, I'm still exploring how I think this is going to work for them. Note that I haven't defined yet how much internal memory or SSD is necessary, but I do know that they have about 100GB in apps and 500GB in documents on their current main drive, so I'm guessing 2TB for the SSD if they want to keep apps/docs in the box (they do).
What I keep finding working with new Mac buyers is that they don't do this sort of contemplation up front, and then they discover they need to add more things and they don't have the bandwidth for it. For instance, the illustrated system pretty much maxes out the 2 Thunderbolt Mac Mini. So much so that I'd move the 2nd display to HDMI out of the Mini box directly.
Thom Hogan
author, Complete Guides to Nikon bodies
bythom.com dslrbodies.com sansmirror.com zsystemuser.com
Thom Hogan
